Results 1 to 7 of 7
Thread: bonnet hinge problem
    PCJ
    PCJ is offline
    Mar 2004
    Default bonnet hinge problem
    I have a 88 vl and sadly the drivers side bonnet hinge has broken.
    the retaining/pivot bolt appears to have sheared.
    because of the location of the fixing point, up back and out of sight, it is really hard to get at.. anyone have any bright hints on easy ways to sort this please
    thanks
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Lightbulb
    Quote Originally Posted by Not_An_Abba_Fan View Post
    I'm not 100% but I think you need to remove the fender.
    I dont know either,
    On the old Valiant it was the same but under the fender there was a panel you took off to get to the hinge..
    Worth a look-you would be pissed off to take off the fender then find you didn't have too!
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    PCJ
    PCJ is offline
    Mar 2004
    Default wing removal
    no it doesnt have a removable plate
    so it looks like i will have to remove the wing to access the hingeing point... bit of a drag, i was hoping there was a way to do this without having to do that...
    Jun 2005
    South OZ Adelaide
    Quote Originally Posted by PCJ View Post
    Hmm bugger
    PCJ
    PCJ is offline
    Mar 2004
    Default possible solution...
    believe it or not holden dont have details of the hinge bolt... and the parts are no longer available..
    but i have had a bright idea...
    if i cut a hole, say 50mm in dia in the outer skin of the offside guard, in the right place, this may give me access to the inner skin and hopefully allow me to remove the old broken stub of the bolt, cos theres no way to access from under the bonnet.
    i can then replace the sheared bolt with one from a wreckers and then refill the hole and respray the guard
    Jun 2005
    South OZ Adelaide
    Arrow
    Yes It might work but If you're 5mm out then that means a bigger hole..
    Just going to have to take of the guard off as by the time you fix the hole ..
  1. Tightening bonnet hinge(body end, not bonnet end)
    By NOGEN 3 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-03-2007, 11:28 AM
  2. Help-VS Bonnet Problem
    By JTW008 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2005, 12:28 PM
  3. Fitting VZ Bonnet Protector problem
    By junka in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 20-09-2005, 04:46 PM
  4. VS door hinge
    By cliffo78 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2005, 11:46 PM
  5. broken bonnet hinge
    By Dezza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-10-2004, 02:11 PM
