Results 1 to 14 of 14
Thread: VL no spark
    VR
    Sep 2006
    Angry VL no spark
    Hi guys,
    My trusty VL went to start this morning no go, no spark
    Dist turns Ok
    no pulses to primary of coil.
    I cant find my wiring diag/schematic amongst my stuff.
    A friend has the ws manual but its an hour each way to pick it up.
    So I guess need to see if pulses are present out of dist back to EFI (connector pinouts) please as a starting point. From memory I think there are 1 degree o/p pulses as well as other angular data.
    If any one could send me the wiring schematic I would appreciate it.
    cheers http://forums.justcommodores.com.au/...cons/icon8.gif
    Angry
    VLturbs87 is offline 1 TUFF SLE
    VH SLE 333 stroker
    Dec 2005
    check ya coil, check your dizzy, and the module...
    If you check all them last thing can be chank angel sensor??
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Few Things. Try Another Coil.
    And plugs on Dizzy and Coil. i have marked in red in attachment.
    I had same problem a few years back and all i did was unplug these 3 marked and sprayed RP7 in them as one was corroded and it kicked straight away.
    Good luck man
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Sorry Please delete previous Post as i forgot attachment.
    Good luck man
    1988 Holden Commodore Vl GTS
    Nov 2007
    well i have just inherited this problem with no spark. i have replaced the dizzy cap, rotor, ignition coil, the sensor beside the dizzy, is there a way to check the crank angle sensor with a multi meter to know if it is working? or any other idea that may be a factor?
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Lightbulb
    Quote Originally Posted by anothercarnut View Post
    Yeah Dude but I don't want to write it out
    This will tell you afm cas spark idle problems? read this - calaisturbo.com.au
    Sticky at top of page ok
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    vxss01 is offline vl calais01
    vl calais
    Mar 2008
    hi got the same problem checked and replaced dizzy and coil other thing
    there are no leds lighting up on ecu could this mean the ecu is the fault
    thanks
    Jun 2005
    South OZ Adelaide
    Post
    Quote Originally Posted by vxss01 View Post
    thanks
    If you have no LEDS lighting up then yes it could be the ECU is stuffed but I'd check wiring and plugs 1st~do you have rust around the base of the windscreen if so water may have been leaking on it...
    vl calais
    Mar 2008
    Default vl wont start
    hi no trere is no rust in car at all amazingly and no sign of water leak thanks
    Jun 2005
    South OZ Adelaide
    Exclamation
    Disconnect the battery and remove the plugs from the ECU are they all CLEAN?
    VR
    Sep 2006
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Quote Originally Posted by iank View Post
    In my case it turned out to be the cas. no pulses out of it.
    regards
    always the problem lol, good to hear mate
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    bit of a thread dig..Ha
  1. Replies: 25
    Last Post: 05-02-2011, 07:52 PM
  2. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  3. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
  4. No spark
    By Terfade in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-06-2005, 09:37 PM
  5. VS SS V8 no spark??
    By Bruce Davidson in forum Electrical Wiring / Questions
    Last Post: 04-03-2005, 07:20 PM
