Results 1 to 5 of 5
Thread: Temp sender
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Exclamation Temp sender
    If you unplug your temp sender the 2 pin one not the flat slide on one, and your car is running and at operating temp What Happens??
    thanks
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    HZ Sandman Ute, HZ GTS, VT Senator
    Apr 2006
    may run rough? may go into limp mode etc? as that is the one for the ecu. the other one that the tab clips onto if for your temp gauge.
    if you need a new one let me know i have a few liying around. =)
    cheers
    jason
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Why would you even want to know this? Unless you have done it and then you would already know.
    Jun 2005
    South OZ Adelaide
    Arrow
    Quote Originally Posted by Not_An_Abba_Fan View Post
    To check it against mine, thats all..
    Yes I do know - the revs pick up a bit but does this happen on other VLs too!!
    vl berlina wagon 6cyl
    Jul 2005
    if the sender that goes to the ecu isnt working properly, I think the engine runs rich, thinking its cold all the time
    BTW is there any way of telling if it is running rich, the tailpipe is always supposed to be black on unleaded isnt it?
  1. VN ECU temp sender
    By hjw153624 in forum Electrical Wiring / Questions
    Last Post: 04-04-2007, 07:59 PM
  2. temp sender
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2006, 10:00 AM
  3. temp sender
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-09-2006, 11:55 AM
  4. Help-temp sender
    By chevy_big_block_bro in forum Electrical Wiring / Questions
    Last Post: 12-09-2005, 01:34 PM
  5. VN temp. sender
    By SAMO-87 in forum Electrical Wiring / Questions
    Last Post: 18-06-2005, 11:20 PM
