There's a throttle stop adjuster on the throttle body what's the base setting 4 this??
Thanks..Mag
Should the throttle plate be closed/open a little/OR
I was confused now I'm just not so sure!!
RIP Peter (perfect) Brock....
run it in diagnostic mode and set the revs to 750-800 rpm and thats your base idle.
no cos when its in diagnostic mode it shouldnt be operating as normal...when you set the idle to 750-800 rpm the idle air control valve adjusts itself to keep the revs at base idle
and by the way mag that little screw to adjust the throttle stop shouldn't be changed unless someone else has messed with it before you and stuffed it up
