Results 1 to 3 of 3
Thread: whether running rich from reading exhaust pipe cplour
    vl berlina wagon 6cyl
    Jul 2005
    Default whether running rich from reading exhaust pipe cplour
    is there any way of knowing the engine is running rich or lean from looking at the inside back end of the exhaust pipe?
    its said the normal colour on unleaded is black
    BTW the normal colour using unleaded with any lead replacement additive is dark mottled grey, close to black, the colour of the plugs depends on the additive
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Arrow
    Quote Originally Posted by harry3 View Post
    Harry forget the exhaust pipe but you can still take a few plugs out and check the colour.
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    another way is just check if the AFM is set to factory standard.
    Get a multimeter and flick to ohms. Hook it up to Pin 1 and Pin 6 once AFM is unplugged
    You should have a reading of 382 ohms
    If not adjust carefully with a flat head screwdriver the screw under the little round cap next to the AFM plug
    Good Luck
  1. VN running very rich
    By 333 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2007, 06:42 AM
  2. Running very rich
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-11-2006, 08:10 AM
  3. Vr V6 Running Rich?
    By struggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2006, 07:43 PM
  4. running rich
    By canb_vn06 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-07-2006, 09:44 AM
  5. Running Rich
    By stheggie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2004, 08:26 PM
