Results 1 to 7 of 7
Thread: door stuck
    VL Berlina 5speed turbo
    Apr 2006
    Default door stuck
    i changed my door handles the other day and i have done something wrong an now i carnt open up my door?
    how can i get it open because i carnt take of the door insert's.
    chers
    VN Wagon,
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If it won't open from either inside or out the only alternative would be to cut a hole in the door trim to get at the mechanism. Or possibly break the door handle and get in that way.
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    yeah youll get a door handle easier than a good matching trim so failing winding the window down and poking around with a bit of wire id be doing something about the handle.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    hmm i would say u have have forgotten to put the wire rod back on the new door handle.
    It is possible to wind the window down and pop the door plugs for the trim and manipulate it enough to pull the rod manually.
    Good Luck man
    Apr 2006
    thank's guy's,
    i did rember to put the rod in cause it worked a few times then ****ed up so not sure whats wrong...
    VN Wagon,
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    there isnt anything to do with the inside handle that has to be removed to do teh outside handle so i doubt itll be the rod or anything obvious.
    How did you go with it?
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    just take the base off the back seat out and you might have enough room to get the trim off,
    is it just out side handle or inside?
    if out side and inside it would be a rods poped off and worst case senario you put child lock on,
    so you will have to pop it open from in side with your hand, once trims off
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
  1. rear door stuck locked
    By kniever in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-06-2011, 02:35 PM
  2. Stuck CD
    By f1_power in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2010, 10:44 PM
  3. im stuck what to do next?
    By calais_304 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2007, 10:45 AM
  4. stuck door
    By Bush VB in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-08-2005, 08:57 PM
  5. Stuck?????
    By liquidforce_134 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2004, 07:48 PM
