Results 1 to 8 of 8
Thread: MSD Ignition Coil
    97 VS Acclaim
    Aug 2006
    Sydney, NSW
    Default MSD Ignition Coil
    How easy is it to install a MSD SS Blaster ignition coil? Is it a simple bolt on and on thing. Do you have to change any wiring if any?
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Arrow
    Quote Originally Posted by ThongyVL View Post
    An SS Blaster you'll need a mounting bracket, there should be enough room in standard spot if not you'll have to extend the wires and coil lead but that depends on where you put it...
    Didn't see the SS bit at 1st
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    VT SS S2 A4
    Aug 2005
    97 VS Acclaim
    Aug 2006
    Sydney, NSW
    Quote Originally Posted by rb26dett View Post
    I have a crane coil on my VL, had to make up a bracket to fit it.
    just wondering are they worth putting them on at all? Even to a sandard engine will it make any performance difference or better fuel economy?
    Jun 2005
    South OZ Adelaide
    Arrow
    Possible but not a guaranteed..
    It's quicker then your mothers VN
    Sep 2005
    At the time of this post, under your mothers bed with my laptop
    Technicaly yes as it will be burning the fuel easier and alot more.
    VT SS S2 A4
    Aug 2005
    My car is running a CDI unit, and it kept cracking the standard coils.
    97 VS Acclaim
    Aug 2006
    Sydney, NSW
    I guess if you use like a MSD 6A Ignition control it's best to upgrade the standard coil to MSD SS Blaster to stop it from cracking. Use both hand in hand and you should be sweet.
  1. Question on ignition coil
    By snowman12 in forum Electrical Wiring / Questions
    Last Post: 23-10-2009, 08:40 PM
  2. Fitting VL ignition coil to an MG
    By bezz in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-12-2006, 11:42 PM
  3. Test VT Ignition Coil
    By daffyy30 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-11-2006, 07:30 PM
