are vl disk brake axles different to vl drum brake axle apart form the obvious fact one is disk and one is drum, is there any other diffence??
Now rolling on 19's
i figured it out the disk axles have a bigger seal on them, if u try put the dick adapter on the drum brake axle when u put the axel in u will get alot of axle float and u will hear the brakes rubbin when u drive.
Now rolling on 19's
