Results 1 to 6 of 6
Thread: Vl Rb30e to 308
    TURBO_VK's Avatar
    TURBO_VK is offline Panel Wagon
    Vk Turbo, and vl wagon v8
    Jun 2005
    Wellington, Newzealand
    Default Vl Rb30e to 308
    alright guys i need any info on changing my 6 cylwagon to 308 v8, eg what auto and manual gearboxes i can use, parts for conversion,would a 4:11 diff be ok??
    Thanks
    1NSANE TOYZ Prezents:
    Vl Wagon--GMH 666--
    Project at 10% CoMpLeTIoN
    100% UnDeRWrApS
    TURBO_VK's Avatar
    Jun 2005
    bump.....anyone????
    Vl Wagon--GMH 666--
    100% UnDeRWrApS
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    so i assume you are going carby then with the 308, right?
    if so what i can figer pritty much just the Kframe out of a v8, crossmember and engine mounts.
    wiring wouldnt be that much harder as you will not need the computer side to run it. possibly fuel system will have to be alterd as its efi and your going to carby, but im not posstive
    trans wise your looking at a trimatic auto or aussie 4speed or even a 5peed manual if you can source one.
    a better route if your dead set on the v8 conversion is the 304i out of the vn-vt range. better econical and power and its fuel injected.
    as for the 4:11's it depends on what you drive daily ie: highway or suburbs and the type of trans and engine used. they will help you decied on the gears
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    TURBO_VK's Avatar
    Jun 2005
    i have found these engine mounts: http://www.trademe.co.nz/Trade-Me-Mo...n-97033436.htm
    if i use them will i still have to change the k frame???
    i am definatly going carb, as i will be going supercharged eventually and im not fond of those under the bonnet superchargers,and im not fussed about fuel economy ether, im most probably stoking the 308 out to a 383,as for gearboxes: if i go auto i would like to go turbo 400 and for a manual would a 4 speed muncy be alright????
    Vl Wagon--GMH 666--
    100% UnDeRWrApS
    TURBO_VK's Avatar
    Jun 2005
    bump!!!!!!!!!!!!!!!!!!
    Vl Wagon--GMH 666--
    100% UnDeRWrApS
    vs commodore ss
    Nov 2005
    aight going from rb30 to 308 is a bit of a downgrade in my opinion but if your going to do it wouldnt be too hard... just get a vl v8 k frame that will already ahve the mounts. you will need a new tranny or if you want to use yours u might need an adaptor and will also need the v8 tailshaft and diff. wiring shoudlnt be too hard and new exhaust. too much effort just turbo your six unbeleivable potential and so many parts oif u no were to look
  1. RB30E Performance chip
    By Flak in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-01-2012, 05:05 PM
  2. rb30e converted to rb30de?????
    By thestash_16 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-09-2009, 01:16 AM
  3. RB30e ECU confusion
    By Krullos in forum Straight 6 Development And Modification
    Last Post: 28-08-2009, 10:34 AM
  4. how much hp will a standard rb30e take??
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-10-2006, 06:43 PM
  5. Rb30e F.s
    By coolvl in forum Parts And Other Items For Sale
    Last Post: 31-08-2005, 11:07 PM
