hey guys and girls. just wondering if anyone on here knows if there is a difference between r33 turbo and non turbo 5 speed manuals? is the turbo one stronger? are they both strong enough for a vl turbo? cheers.
so are they the same strentgh? do you know which has the shorter ratio's and which has the longer? cheers.
ok well, all i need to know now is the strength. cheers. surely theres someone on here that would know.
defently the turbo will be stronger,
i assume its like the vl and vlt 5speeds, the turbo one is stronger to cope with the extra grunt
possiblity of extra syncro on the turbo box, but thats just a thought
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
yeah i would guess that the turbo would be stronger also. but i want to know for sure. thanks.
thanks for that. so a r33 non turbo box should be good enough for a vl turbo? do you reckon it would be stronger then an mx7? cheers.
thenks for that. but is mx7 stronger then r33 n/a? cheers.
ok sweet thanks. think i'll just put an mx7 in it then. can you still use the n/a clutch and flywheel. cheers.
oh ok. that does sound abit more beleivable. was wondering why the mx7 would have been the nicer box. but i read the less use part as less fuss for some reason. well i can get an r33 n/a box for $495. not sure how much for a turbo one though. cheers.
thanks. will go down there tomorrow after work and see if they've got one in et and how much they want for it. cheers.
