Results 1 to 10 of 10
Thread: crank angle sensor?
    vl berlina wagon 6cyl
    Jul 2005
    Default crank angle sensor?
    my VL wont start and Ive been told its the following: its the crank angle sensor, a common problem, its inside the distributor and too difficult for me to replace
    does this sound right? I thought it was down near the crankshaft
    any comments appreciated, cant find mt workshop manual at the moment either
    could I get a new sensor at an accessories place or only a holden dealer, how difficult is it to fit?
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Arrow
    Quote Originally Posted by harry3 View Post
    Make a few calls there about the place and don't see why you can't do it ur self as many novice's can!
    Its inside the distributor just find that workshop manual
    Do you have any spark??
    Attached Thumbnails Attached Thumbnails crank angle sensor?-crankanglesensorvl.gif
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    Jun 2005
    South OZ Adelaide
    Arrow
    Here too Harry $80 it says
    Jun 2005
    South OZ Adelaide
    Jul 2005
    the rotating wheel with the slots in it for the light to shine thru is very thin and Ive been told is easy to bend
    has anyone here actually done this job?
    does a new wheel come with the sensor?
    should I undo the 2 bolts holding the top part of the LEDs to make it easier to get the disc off
    if I do the job with the dizzy still on the engine, will any adjustment of the timing be needed?
    thanks for all help, my workshop manual says very little about the job
    executive vt 5.0lt
    Feb 2005
    west suburbs
    just go to an autoelec shop and exchange it only cost $100
    exchange the whole dizzy
    Jul 2005
    a new crank angle sensor often comes with a shaft bearing and electrical plug and I ws quoted $150 and $200 from 2 places, a lot more that the $90 from IOL
    an reconditioned dizzy with new sensor and bearing was $ 285 exchange
    I finished up getting an autoelectrician to come and fit an exch dizzy for $320 since I wasnt totally sure it was the problem and my eyes are too poor to use a timing light
    general advice was the main electrical plug to tne dizzy usually corrodes, this often causing failure of the sensor, often corrosion is so bad that a new plug is needed, so the plug often comes with the new sensor just in case
    mine wasnt corroded at all and needed no attention, but I urge all 6 cyl owners to remove the plug and attend to any corrosion, also make sure plug cover is stopping any water from getting in
    also the rotating wheel in the dizzy is easily bent and must be marked to stop it going back the wrong way round as it wont work properly
    cheapest way would have been a dizzy from a wrecker and hope for the best
    racv bloke said engine very good usually, the sensor being the only thing that goes wrong, along with the temp sensor connection for the ECU occasionally
    autoelec bloke said the VL was the most reliable holden ever made, because holden got the engine and auto trans from nissan, OUCH !
    executive vt 5.0lt
    Feb 2005
    west suburbs
    i just went to the autolec shop and got it for 100 i think you got riped off
    warney's Avatar
    warney is offline did you say bukakki party
    VL skid car what else are they built to do
    Mar 2005
    Quote Originally Posted by gungazza View Post
    wheres your auto elec shop if ya dont mind me asking ????
    Nov 2006
    My daughters car I think has same problem. runs well for me, she drives it and it just stops in the middle of the road and wont restart! I get out there to have look and if fires up fine.....
    Today it did the same, I drove it home as usual while she drove my car, got 100 metres from home and it stopped dead on me. Have been checking the diagnostics codes every time it fails and it keeps coming up with the crank angle sensor failure. Found one on ebay today for $70 + $7 freight, brand new. He has 5 of them, as of tonight (8th May).
    Still a lot of money to spend if its not the problem tho.....
    Anyone have an electronic copy of the manual? mine has bout 50 pages missing out of the middle - of course its the section covering the damn distributor...
    EDIT: Spoke to my brother (mechanic, but 1200 km away..) he said to steer clear of the ebay ones as they are inferior quality, and if they work, they dont usually last long. So I bit the bullet and bought a kit from Repco, cost me $120 (trade price - normally $169.99). But it came with the bearing and a new plug for the cable. Installed it all this arvo, the old bearing was crapped out, exactly as they warned it might (red dried up grease powder and sand like granuals everywhere and the bearing turns like its full of sand). So replaced them all, fired up straight away, have done bout 20km and it hasnt stalled again yet.
  1. crank angle sensor
    By craigillz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-03-2009, 12:38 AM
  2. crank angle sensor
    By aurace in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-04-2007, 11:20 PM
  3. Crank Angle Sensor
    By Stretcher Bearer in forum General
    Last Post: 22-11-2005, 03:22 PM
  4. how much for a Crank angle sensor???
    By CSL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2005, 11:32 AM
  5. Crank angle sensor
    By chevy_big_block_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-07-2004, 06:06 PM
