Results 1 to 4 of 4
Thread: Fuel Injectors, easy enough to clean or change yourself or not?
    VL Commodore 3.0 litre
    Jan 2007
    Default Fuel Injectors, easy enough to clean or change yourself or not?
    Hi all, just curious about my fuel injectors they have never been cleaned or looked at in the time I have had my VL and I know they could use some TLC. Just wanting some advice about cleaning or changeing them myself. Is it easy enough to do or should I leave it to the mechanics/auto elec? If anyone has done them their selves info on how to would be much appreciated.
    Some pics would be great if anyone has them.
    CHEERS AND BEERS :
    Last edited by Damon Daniel; 04-05-2007 at 12:33 AM. Reason: wanted to ask another question.
    VL
    Jul 2006
    i've changed a few. here's a run down of how to change them:
    1- depressurise the fuel system
    2- drain coolant
    3- remove intake pipe and breather hoses
    4- remove all vac, breather & coolant lines from plenum
    5- undo the 4 top and 3 bottom plenum bolts and remove
    6- undo fuel hoses, and rail bolts, injector retaining screws and remove rail and injectors in one assembly
    7- using circlip pliers remove the retainer from the injector
    8- remove injectors from rail (they'll be pretty well stuck)
    9- you can replace the injector pintle caps if you need to by just pulling (or breaking) the old ones off and pushing on the new. they clip in when they are on fully
    10- while they are off you can get them cleaned/throw them in the bin or whatever and then reinstall.
    11- remember new o-ring seals on the injector to manifold join is a good idea and so is a new plenum gasket. may as well clean everything up too while you are there also you may as well change your coolant and DON"T FORGET THE BLEEDING PROCEDURE! if you dont want a cracked head
    thats about it i think....i'm in a bit of a rush so probably forgot something
    by the way on your first attempt at doing this it will take a while probably 2-3hrs, with a workshop manual and some patience it isn't that hard just take your time and be careful
    VL
    Jul 2006
    oh and there are heaps of hoses to remove from the plenum so make sure you label them if you think you'll forget where they go and make sure you do the clamps up tight when you put them back on. nothing worse than leaks (air or coolant) to piss you off after doing it all the first time
    Jan 2007
    Thanks for your help snake, been real busy, just getting back into fixing up the VL!
    Smoke 'EM' Up!
  1. injectors... time for a clean ??
    By beefcream in forum General
    Last Post: 09-11-2007, 11:29 AM
  2. Clean or replace injectors?
    By kopper69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-04-2007, 02:56 PM
  3. When to replace/clean fuel injectors.
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2007, 01:56 PM
  4. How Do I Change Fuel Injectors On A Vl
    By dbombardo in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-09-2005, 05:33 PM
  5. can you clean fuel injectors yourself?
    By 94 VR BT-1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2005, 07:27 PM
