would i be able to use the setup for the disc's of a disc brake vn or vp?
(EDIT)
1NSANE TOYZ Prezents:
Vl Wagon--GMH 666--![]()
Project at 10% CoMpLeTIoN
100% UnDeRWrApS
highly doubtful
yes you can, i have looked into this and it is just as easy to go buy a whole disc rear end and its almost cheaper
you need
- disc
- calipers
- the brake lines(metal that runs acros diff top)
- disc backing plate
- handbrake brake set up
- a vl disc brake handcable (vn/vp are to long)(pritty sure vb to vk cables are ok)
- and the seals on your axels will need to be cahnged to disc seals or you will leak diff oil
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
