Results 1 to 4 of 4
Thread: running rough at start up
    starfire vc's Avatar
    starfire vc is offline now on 10 pound
    VL turbo, RB30ET VH wagon, 64 EH in the build.
    May 2007
    Brisbane,North
    Default running rough at start up
    ok when i go 2 start the old girl it will run rough 4 the 1st few seconds and then it goes good. its an intermitant problem coz other times it will start and run fine.any ideas
    the germans designed it, the aussies built it, the japs got it moving and the wogs got it dosing...
    VY SV8 HBD---mmmm LS1
    Simon Champion! On The Volley Champion! Shootin Hoops Champion! Batting Champ Champion!
    Dec 2005
    Western Suburbs
    same thing happens 2 me i was thinkg it my be my throttle body cleaned it 2day quickly was the same might have 2 take it off and clean it props or fuel filter/pump mayb
    vl berlina wagon 6cyl
    Jul 2005
    with the 6 cyl engine, you need to switch on the ignition than wait until you hear the fuel pumps stop running so the fuel system is properly primed, if you dont wait, the engine will run roughly at first for a while
    May 2007
    Brisbane,North
    thanks all. found the problem tho. it was an air leak in the vent controll switch , all sorted now
  1. vs v6 running rough
    By nuggetbum in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2006, 04:56 PM
  2. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  3. vl running rough
    By scozzman in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-05-2006, 12:42 PM
  4. VR ute running rough
    By FREESTYLE_MX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2006, 11:56 PM
  5. VS Running rough after start
    By Neile in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2005, 07:24 AM
