Are you selling 1 or buying ??
Last time I did mine on the VL, from memory which is bad, I paid almost $40.
I bought 1 from a holden dealer for about 6 dollars
Ive been told that they now last much longer and can be safely left beyond the holden change interval
mate i have two brand new gates brand ones here. wont get any better quility. i brought them and never used them. both are brand new. make me an offer on either 1 or 2 inc the post cost if you want.
cheers
jason
^ As above, gates are far and away the best brand on belts.
Brand new they're $24, or for the Gates Racing Timing Belt to suit $88.
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
I have used the Gates racing belts and recommend them.
Its the labour thats the killer. I'm not keen to try it myself but am needing to replace mine soon I'm guessing that the current timing belt prolly has 170,000 km's on it seeing as my car has 270,000 on the clock. (221,000 when i got it and I assume it wasn't changed)
if you're doing all the work for a timing belt then you should do the water pump and front oil seals at the same time. it'll only take an extra 1/2 an hour to an hour.
