Results 1 to 15 of 15
Thread: Whats the go with the spark plugs..
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default Whats the go with the spark plugs..
    Serouis, i dint take notice of my ngk ones lastnight, after i pulled the bosch ones out.. then my mate sends me a txt saying to get bosch plugs... no fken wonder there like a 21 for NGK unlike the bosch which are like 15.. i couldnt find a single tool to fit my NGK's lastnight without carving up the rocket cover.
    So i went back today and scored the bosch plugs...
    my advice is dont buy NGK plugs for your VL! I've got allot of tools and i had no luck!
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Interesting. I use nothing but NGK unless I absolutely can't get around it and I have never had any problems. If you had the correct plug socket you shouldn't have any dramas.
    Visit my Facebook page
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Oh i had the correct sockets just the rocket cover wouldnt allow them to fit..
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I wonder how they were put in in the first place?
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    have always used NGK plugs in my vl's there is no diffrence in fitting.
    what was the problem, was the sockets out side pushing on the rocker cover not alowing it to reach where the plug is?
    simple just get a spark plug socket which fits the plug and is thin walled not chuckny.
    it doesnt need to be strong as little tension is need to tight the plug to a sutiable level
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    '87 VL Calais with L67
    Aug 2007
    Quote Originally Posted by VL Berlina 5speed View Post
    yeah but getting them undone next time is going to be a bastard
    Goon's Avatar
    Feb 2006
    GC. QLD
    Was a hell fof a mission removing plugs 3 and 4 without removing the EFI, had the wacky socket setup happening "bosch plugs so easy to fit" 2 or 3 clicks at a time what a B! the others where easy!
    It's quicker then your mothers VN
    Sep 2005
    At the time of this post, under your mothers bed with my laptop
    i dont get how everyone complains about vl's and spark plugs, there a peice of cake. go do the spark plugs on a xy 351 then complain
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Exactly, or even better, the first of the V6 Sonata's. Jack the engine up to get the back three.
    Getting at the passenger side rear extractor bolt is fun on the 351 too.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    while were at things that are hard to get. on my dads 93 4.2 petrol Patrol, (besides spark plugs) the rear passenger side exhaust manifold bolt is the biggest pain, its virtually sitting against the firewall behind the manifold. We had to get a socket with a uni joint to get to it then blindly try undo it. Putting it back on was even worse!! seems spark plugs are hard on all nissan straight 6 motors.
    Power is measured in DECIBEL
    vl berlina wagon 6cyl
    Jul 2005
    VL 6 cyl sparkplugs require a wobble joint or uni joint to allow for some sideways movement of the socket shaft
    smashesd insulators from side pressure and crossed threads are a risk
    it helps to place some plastic tube over the insulator to help getting the thread started by hand
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    As the man says always used NGK plugs and not just VL's either
    Attached Images Attached Images
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    i allways use ngk .champion are allways no good in holdens i reckon. bosch have let me down before a few times. i have noticed that ngk must be changing there sizes cause i swapped plugs in the fzr1000 and i had too buy a socket too get them out then the new plugs were a different size i actually used the small holden size socket to put the new ones in if i remember right it was a wee while ago.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    I've always run NGK for 15 years and they have always done me well.
    Reaper
  15. #15
    Oct 2005
    Quote Originally Posted by Acclaimed View Post
    getting them undone? whats the problem.
    as many have said the use of one or two flexable joint/uni joint in the socket is a must to access plugs 3 and 4
    a spark plug in a vl is like the oil filters, it should not be done tight to the point it will rip the thread. hand tight is the limit,
    being a alloy head it will expand and shrink alot from heat and will cause the plugs to cease in the holes if there tightened to there limits
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  1. Replies: 25
    Last Post: 05-02-2011, 07:52 PM
  2. best spark plugs to use
    By jamo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-09-2006, 10:01 PM
  3. spark plugs
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2006, 01:42 PM
  4. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
  5. Spark Plugs
    By YBLGIT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2004, 09:17 PM
