last week, before the site crash ,there was a thead on here ,about a member haveing cooling probs ,useing water and no water returning to header tank, a new radiator cap was recomened ,ect ,i have the same prob, and i was checking things yesterday ,and i found the tank had corroded and gone brittle, leaving a split about 4 inches long , could this be the problem using water and not returning to tank, because the system is not sealed ??![]()
if ya want a new rad drop me a line as i have one here.
cheers
jason
I take it that the reservior is the thing that has gone brittle and cracked and not the actual radiator? Then yes, when it warms up, coolant flows to the reservior and out the crack, when it cools down there is not enough coolant to return to the radiator so it will be low. Get a new reservior.
yes that sounds more like it ^^^
yes the reservior is the prob where the split is
the crack is at the top so no water is getting out
driving down the road, takes a left turn.
gravity pulls to the right (out side of car)
petrol in tank goes to the right side of it,
the bottle of distiled water in the boot for the emergency vl over heating problem sloshes to the right
so what does the coolant in the over flow tank do?????
sloshes to the right where the crack is......... sounds about right to me - or you got a leak![]()
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
you must be going around corners on 2c wheels![]()
