Results 1 to 6 of 6
Thread: running rough
    vl commodore berlina
    Sep 2007
    Default running rough
    hey everyone,
    my baby seems to be running rich and really rough. when i put her in gear she just seems to die in the ass. think there is a prob wit oxygen sensior coz i unpluged it, started the car and pluged it back in and she ran fine for about 5 min. but almost certain this is not the main cause.
    i know **** all about cars but i love her and dont have the money to spent hundreads of $$$ to find out the prob then extra to fix.
    if anyone has any suggestions of what i can try to narrow the prob please let me know.
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    Apparently the VL's had a problem with the fuel return line going back to the fuel tank clogging up and causing excessive fuel pressure and consequently putting too much fuel into the engine. Maybe you could pull off the fuel return line and try to blow down it and see if its blocked(do so at your own risk), or pay to get a fuel pressure test done (shouldnt be more than about 50 bucks).
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    If its not a fuel problem, crank or oxygen sensor, could be timing or a connection problem.. I'm new to VL's myself but its just my brainstorm thoughts about ur issue..
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Make sure the clamps on the AFM are tight, also when its running, wiggle the plug on the AFM and see if the idle changes.
    Visit my Facebook page
    VL Calais Turbo
    Sep 2007
    Heres a few things to try..
    Check the codes on the computer (passenger side kick panel)
    CODES ARE:
    11 Crank angle sensor circuit
    12 Air flow meter circuit
    13 coolant temperature sensor circuit
    14 Vehicle speed sensor circuit
    21 ignition signal circuit
    23 throttle switch circuit
    24 neutral switch circuit
    31 satisfactory operation (non air conditioned models) air conditioner circuit (air conditioned models)
    32 starter signal circuit
    34 detonation sensor circuit (turbo models)
    44 satisfactory operation (air conditioned models)
    AIRFLOW METER....Get the car up to operating temperature. Then on your air flow meter you will have 6 wires (numbered 1 to 6).
    Using a multi meter connect the red wire to wire No.6 on the air flow meter and the black wire to earth, this should give you a voltage.
    Turn the screw on the side of the air flow meter so the voltage reads 3.61volts.
    (If you cant get it to read 3.61v replace the AFM)
    Also try:
    Crank angle sensor - Wiggle the plug if the car turns off or runs rough check the plug/connection if ok then replace sensor.
    O2 sensor - remove it and give it a clean (can get **** in it) replace if necessary
    Coolant temp sensor (the one with an injector type plug)
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by whistle View Post
    CODES ARE:
    Also try:
    Cheers, ill be checking this out in the morning!
  1. vt rough running
    By Jaybee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2009, 04:37 PM
  2. Help! VL running rough
    By charlene in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-11-2007, 07:12 PM
  3. vs v6 running rough
    By nuggetbum in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2006, 04:56 PM
  4. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  5. VN running rough
    By modcon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2006, 08:26 AM
