Results 1 to 14 of 14
Thread: surging and stalling
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Default surging and stalling
    my wife has had it stall 8 times in a short distance, once while driving but the others when at sitting at lights. also when changing from park to reverse. but it only ever happens when the engine has warmed up. i took it for a spin and i was into it and it would only surge when the revs picked up but nevere stalled. i thought maybe the temp sender. haven't done diagnosis check yet. but i checked the intake pipe and it had separated between the TB and filter. would the sucking of hot air from the exhaust cause these problems? as in the ecu thinks there is cold air going in and puts more fuel in but there's actually hot air going in so it's over-fueling. the exhaust was a bit smelly.
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    VL 6 crank angle sensor
    VL 8 worn cam lobe/lifter
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by bangers View Post
    i replaced the CAS not that long ago.
    are you generating any error codes?
    is the comp "OK"
    Powered By Garrett
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    i haven't the chance to do a diagnosis with the ecu and get codes. i haven't checked the compression but she's only done 150,000kms.
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    sorry "comp" i was refering to your computer!
    the VL rb30 motor will not have a compression problem.
    very reliable donk!
    Powered By Garrett
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Arrow
    Air flow meter or its plug..
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Not a timing problem at all ?
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    vl berlina wagon 6cyl
    Jul 2005
    there mustnt be any leaks in the induction between the AFM and the engine, the flexible rubber sections can split with age
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Mine had a similar issue where the Dizzy was defective and the shaft was moving up and down (too much play) and was knocking out the CAS but when you jiggled the big plug on top it would fix it for a bit. swapped the dizzy over and it never stalled again. Yeah and there must be no air leaks or the engine will not get a correct A/F ratio and that will also mess things up.
    ========My Statesman 20's Mafless and 3.9's========
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    well it's not as bad since i fixed that pipe. i went out this morning in it and it went to stall a couple of times but it may have been my reflexes of puting it in neutral in touching the throttle that kept it going. a mechanic friend of mine told me to bring it to his shop one saturday soon and we'll play around with it. luckily i'm in no rush now after buying the new car. i still think it's either the AFM or temp sender. he agrees.
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    well i changed the temp sender and it's not as bad. I took it for a run and one the temp guage reached the 3rd bar it stalled as soon as i came to a stop at a round-about. yet when i got home i stopped at my driveway and she didn't stall again. The plug is busted and i've got it taped on, maybe that's the problem?????
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    well i reset the ecu and now it's all good. just have to sell the car now.
    VL Berlina RB30
    Oct 2007
    West Coast NZ
    how do you reset the ecu????
  1. Help! car stalling, surging, pinging. CAS changed.
    By vn calais manual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-11-2007, 05:24 PM
  2. Need Help ! rough idle, stalling, surging
    By steve_o_85 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-02-2006, 09:17 PM
  3. V6 surging
    By totality in forum V6 Development And Modification
    Last Post: 07-02-2006, 06:49 PM
  4. surging...
    By Boonz in forum General
    Last Post: 25-08-2005, 11:59 PM
  5. Surging VS 5 lt
    By FastEHHolden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-09-2004, 07:48 PM
