Results 1 to 8 of 8
Thread: bonnet cable issue
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default bonnet cable issue
    Hey all
    I have to pull my lever then push the bonnet down for it to open.. think its old and warn out? or just needs to be tighten ?
    Goon.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VL Berlina Station Wagon
    Sep 2007
    Maybe compression spring on striker bolt, attached to bonnet has had it,or spring on car body ,just in front of rad. is broken.Striker bolt can be ajusted with screw driver to lengthen or shorten.Hope this helps mate. Martin
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by My Car View Post
    Sure does mate, thanks a million!
    I'll be sure to post when i fix it
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Chances are the cable has stretched. Very common on a car that is 20 years old.
    Visit my Facebook page
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    I have never seen a VL where you can pull the leaver and expect the bonnet to open.
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    If its the same cable setup as a VN (I suspect it would be) the sheath at the end of the cable (near the striker) is held in place by a bracket held by a crappy self tapping screw which comes loose and allows the cable sheath to drift around, effectively "lengthening" the cable. If it has only started doing it recently then the cable is probably stretched or the sheath bracket is loose. If its the sheath bracket the easiest solution would probably be to move the bracket down a bit so you can drill a new hole and do it up tight, I say probably as ive never done this, I usually do it the dodgy way and cable tie it to the radiator support near the headlight which stretches the sheath out effectively "lengthening" the cable.
    executive vt 5.0lt
    Feb 2005
    west suburbs
    Quote Originally Posted by VL_5SPEED View Post
    no probs with mine, only the fuel system not playing lol
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    just one more thing aswell as what has been posted above the car is twenty yrs old and the whole bonnet catch mechanisim probably hasn't seen any oil for about 15yrs. oil up, work it several times and adjust the striker
    Nobody wants to play with me
  1. Bonnet release cable snapped how do i open the bonnet
    By S-Pac_Sam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2010, 09:07 PM
  2. bonnet cable
    By zohpm in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-04-2007, 04:12 PM
  3. bonnet cable broken please help
    By jolea682 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-01-2007, 05:16 PM
  4. broken bonnet cable????
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2006, 07:56 PM
  5. Broken Bonnet Cable
    By Pub247 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-07-2006, 04:43 PM
