Results 1 to 5 of 5
Thread: rb30 missing down low??
    starfire vc's Avatar
    starfire vc is offline now on 10 pound
    VL turbo, RB30ET VH wagon, 64 EH in the build.
    May 2007
    Brisbane,North
    Question rb30 missing down low??
    ok all. ive got an intermitant prob with the old girl, she seems 2 miss under light accelaration. once u put ur foot in its ok. but yea iam not sure wat could be causing it??? any ideas any one. cheers
    the germans designed it, the aussies built it, the japs got it moving and the wogs got it dosing...
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    I had a similar problem to I took off the aac valve and the little plunger was stuck so I pulled it out carefully with pliers and cleaned IT and the chamber sprayed a little silicon spray on the plunger/valve slipped it in and out a few times put it all back together and no more miss under light acceleration I suspect this is common as this happened to both my vl and her vl
    Nobody wants to play with me
    May 2007
    Brisbane,North
    hey cheers mate. what does the acc valve do and what does acc stand for?
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    AACV auxiliary air control valve is part of the IDLE AIR adjustment (when there is no air flow, vehicle is IDLE) EGR exhaust gas recirculation.
    aacv is the little round cylinder with an electrical connection at the rear of the plenium chamber (disconnected when adjusting the idle speed and timing)
    inside is a valve (looks like a water tap washer) it gets stuck and clogged with exhaust carbon and needs to be cleaned and lightly lubed (I use a little bit of silicon spray)there are only two screws then remove slowly so as not to lose the spring inside.
    May 2007
    Brisbane,North
    hey cheers mate cleaned it all out .problem fixed. thanks 4 that
  1. Nissan RB30 V Holden RB30???
    By neatvl86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-01-2011, 01:08 AM
  2. t5 to rb30 plz help
    By vks in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-09-2007, 11:35 PM
  3. What does the RB in RB30 mean?
    By HSVenforcer in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-04-2006, 10:32 PM
  4. RB30 into the vh
    By vh-holden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-10-2005, 05:52 PM
  5. RB30 into VH
    By dibly1980 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-03-2005, 11:21 PM
