ok Im doin an na conversion to turbo, got turbo injectors, t3 turbo and manifolds..... to run standard boost can I use the standard ecu and fuel pump? been told I can adjust the fuel damper to allow more fuel without upgrading fuel pump....anyone know if this is correct? and are the na and turbo dizzy the same? thanks
thanks Mag......so will car run ok on standard boost with na computer?
it will run ok yes.
the best way to do it is get your n/a computer remaped for turbo injectors (a guy on r31skylineclub does them) that way you dont have to run a knock sensor
if you do use a turbo computer you need to hook up the knock sensor or is acts as the motor is detonating and drops the timing off so you have bugger all power
I was confused now I'm just not so sure!!
RIP Peter (perfect) Brock....
whats the cost to get na computer remapped?
Yeah turbo injectors are a 2 stage item i.e. when on boost more fuel is added to cool the pistons as there was no factory intercooler. when off boost they will be the same as a normal na injector. So perhaps if you ran an intercooler and stock boost the boost stage would not be necessary as the charge air is cooled from the intercooler and such a rich mixture would not be required (so much).
about $40 i think Welcome - R31info i think his name is darkhalf
i cant get mine going, itnever mind turboing
