Results 1 to 12 of 12
Thread: crank angle sensor died
    starfire vc's Avatar
    starfire vc is offline now on 10 pound
    VL turbo, RB30ET VH wagon, 64 EH in the build.
    May 2007
    Brisbane,North
    Angry crank angle sensor died
    ok well my crank angle sensor decided itd had enuff today. washed the car went 2 drive her outa the carwash and no action. so i push her off 2 the side and go thru everything. eventually had a look 2 see if any fault codes had come up on the computer.number 11 was showing crank angle sensor. so ive just paid 100 buks 2 get her towed home. any ways how much is a new crank angle sensor goin 2 set me back? the sensor that was in it is only just ova a year old , they shud last longer than that! allso would a crank angle sensor on itsway out be causing any otha problems with running like rough idle or do they just stop? cheers
    the germans designed it, the aussies built it, the japs got it moving and the wogs got it dosing...
    vl berlina wagon 6cyl
    Jul 2005
    corrosion in the electrical plug on it may be the problem, made worse by water from the carwash
    the complete distributor head is usually reconditioned by an auto electrician if its not just the plug, a kit is available
    also theres supposed to be a gasket under the dizzy head to keep water out
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    you can buy the plug separately for about $20. do that first and see how you go. if the CAS is stuffed again after only a year then something is causing it to die, and that is most likely the dizzy bearing. easy way to tell is there will be orange powder in the dizzy if the bearing is stuffed.
    May 2007
    Brisbane,North
    allritey pulled my dizzy out this arvo the connector is a bit corroded.seal is hard and wouldnt hav been doin much. question .the timing notches on tha balancer ,the center 1 is tdc right?? think iam just goin 2 rebuild the whole lot new cas bearing , connector.. allso do i hav 2 erase fault codes on the ecu???
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    No! to fault code
    Tdc mark is the top one on the balancer ( the yellow one)on the compression stroke facing the engine turn the engine over clockwise it is the last mark to pass the pointer
    Nobody wants to play with me
    Jul 2005
    the rotating tone wheel is easily bent and should be marked to prevent it going back wrong way round
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    You pulled ur dizzy out, u crazy goodluck mate! I hope u know how to fix it mate, i really do.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    May 2007
    Brisbane,North
    Quote Originally Posted by Goon View Post
    hahaha yea mate i pulled it out. got a new crank angle sensor. rebuilt my dizzy but her all bak in and she went. cheering
    VT SS S2 A4
    Aug 2005
    Pull your dizzy out, throw it away.
    Get yourself a series 3 Skyline Dizzy and say goodbye to CAS problems.
    May 2007
    Brisbane,North
    Quote Originally Posted by rb26dett View Post
    dont think ive eva heard of that 1. are they just a beta dizzy?
    Jul 2005
    the skyline and VL dizzy heads are not interchangable and a skyline head new costs a fortune being genuine nissan only
    VT SS S2 A4
    Aug 2005
    Best option is to get a complete dizzy from a series 3 R31 skyline, it has a Mitsubishi CAS in it and it is 100% reliable and gives a clean signal output.
    you need the complete dizzy because it uses a Mitsubishi rotor button as well, which is different, and will not fit in the vl dizzy.
    the dizzy cap is interchangeable however.
  1. Crank angle sensor
    By batemada in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-11-2007, 05:38 PM
  2. crank angle sensor?
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-05-2007, 09:23 PM
  3. Crank angle sensor - How much?
    By Clinster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2007, 09:42 AM
  4. Crank Angle Sensor. WHY??
    By Chuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-12-2004, 08:02 PM
  5. Crank angle sensor
    By chevy_big_block_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-07-2004, 06:06 PM
