Results 1 to 10 of 10
Thread: Putting in new diff oil and replacing diff gasket ?
    Nissan 300ZX TT
    May 2005
    Default Putting in new diff oil and replacing diff gasket ?
    Hey guys the diff on the VL has tons of leaks on it so i think i need to replace the gasket.
    Ive never replace diff oil before so whats the best non messy way of doing it ?
    EDIT: obviously never changed the diff gasket too.
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    The thing I found wrong on it, which im not sure if im correct, but wont using kero 4 cleaning cause contamination?
    Water would be best?
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    Nissan 300ZX TT
    May 2005
    Quote Originally Posted by DARKVL View Post
    Thanks mate, I was gonna do just that but wasn't sure if it was the correct way
    vl berlina wagon 6cyl
    Jul 2005
    normally the diff oil needs to be sucked out with a syringe or sludge pump, as unlike earlier holdens, you cant drain it by removing a bottom bolt, will help to do after a run as the oil will be warm
    probably should be changed about every 10 years as maybe the additives in it eventually get worn out
    Sabbath''s Avatar
    Jul 2006
    Quote Originally Posted by harry3 View Post
    Or, as said in the guide, you can undo all but the top two bolts, undo them 3/4 of the way out and then crack the seal on the diff with a screw-driver. The oil will then drain out and the last two bolts can be removed
    Much faster/easier way than trying to manouver any kind of pump under there
    It's quicker then your mothers VN
    Sep 2005
    At the time of this post, under your mothers bed with my laptop
    Quote Originally Posted by Goon View Post
    yeh use water while ur there pour some into the intake manifold helps build compression
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Water and oil don't go 2gether.....so don't use water. If ur just changing the oil and the gasket, remove all the back plate bolts, chuck a bucket or sumfin under the diff, use a screwdriver to lever the backplate off....slowly first so it don't come gushing out and all over u, use a razorblade or sumfin similar to clean the old gasket off, do it for the housing and the backplate, either get a gasket or use some silicone based gasket gear in a tube, wipe it all around putting a fair bit on both the housing and the backplate...then put them 2gether and bolt them up. Wait a few minutes then chuck the oil in and away ya go. I think ya might have to wait for the silicone gasket stuff to dry a bit b4 ya put oil in, but when we did it (when we just chucked the new diff in), we wanted to try it out, so we went onto a 'private' block of land and laid a skid....it never leaked...altho it was out within a week coz it needed replacing....nothing to do with the oil tho .
    Jul 2005
    the plastic suction tube on my syringe had to be lengthened to let it reach to the bottom of the housing and suck out all the oil
    its a good idea to check the rear axle breather which can become clogged with mud causing many oil leaks
    vl executive
    Sep 2007
    easiest way is to undo all the bolts, split the cover off, clean the diff housing and cover plate, use either the blue hi-temp gasket goo or gasket, then use 80-120w lim-slip diff oil,(the same used in falcons, and its bluey-green in colour) the best stuff to use. be careful when pouring as to not knock the wires to fuel pump.
  1. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  2. Replacing the standard diff with LSD
    By CustomVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2006, 05:28 PM
  3. Whats involved replacing IRS with a solid diff...
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2006, 02:43 PM
  4. Replacing VL Diff Oil
    By jetspin_vn in forum Holden Commodore How-To's
    Last Post: 07-09-2004, 03:39 PM
  5. Replacing The Diff
    By jules in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-02-2004, 01:46 AM
