Results 1 to 8 of 8
Thread: what will this do ?
    86 VLCT/ 03 II VY SS Ute
    Aug 2007
    Default what will this do ?
    yesterday i was replacing my antenna whe i found my computer on the passenger side behind the little guard that i neede to get behind to take the outside panel off. anyway i noticed a little switch (that to reach you have to use a screwdriver) on the front and it had high and low it was sitting just over half way to high.. what will it do if i turn it up or down ?? thanks in advanced
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    not 100% sure maybe idle control, best not to touch it if you dont know what your doing and your car is working.
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Its used for putting the car in and out of Diagnostics mode, where you can find out the "Fault Codes" by reading the two LED's also contained on the fascia of the unit. It can also be used to make subtle adjustments to the idle speed i believe as there are other places where idle speed can be adjusted from. But should only be adjusted if it is out (Should be around 700+- 50)
    As has been said, do not force it or turn it hard. If you have a Gregories/Haines/Ellery manual there should be a chapter in there with reference to the computer and the fault codes and such.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    Aug 2006
    TO CHECK ERROR CODES:
    1. remove screw retaining the passenger side kick panel
    2. turn the diagnostic mode selector fully clockwise to diagnostic
    3. start the engine and let it idle
    4. watch the LED's flash (red and green), the red represents tens and the green represents ones (so if the red flashes twice and the green 4 times, thats 24). 14, 23, 24, and 31 should show
    5. drive the car above 10km/h, this will cancel code 14
    6. stop the motor and then turn the ignition to the on position
    7. press the accelerator, this will cancel 23
    8. put the car in neutral, then back into another gear, then back to neutral. this will cancel 24
    9. turn the air con on, then off this will cancel 31
    10. look at the codes that are now displayed, 31 means you dont have air con or its not working and 44 means your air con is working.
    11. any other codes displayed besides this means there is a fault in that section
    12. turn the diagnostic mode selector back full anticlockwise then turn the ignition off.
    13. erase the memory by turning the ignition on, then moving the diagnostic mode selector fully clockwise for 2 seconds, then fully anticlockwise for 2 seconds. turn the key off and the memory is now cleared
    CODES ARE:
    11 Crank angle sensor circuit
    12 Air flow meter circuit
    13 coolant temperature sensor circuit
    14 Vehicle speed sensor circuit
    21 ignition signal circuit
    23 throttle switch circuit
    24 neutral switch circuit
    31 satisfactory operation (non air conditioned models) air conditioner circuit (air conditioned models)
    32 starter signal circuit
    34 detonation sensor circuit (turbo models)
    44 satisfactory operation (air conditioned models)
    __________________
    Aug 2007
    vl berlina wagon 6cyl
    Jul 2005
    water leaking in thru a rusted wind screen surround can damage the computer, some recommend placing a plastic bag over it
    VT SS S2 A4
    Aug 2005
    Quote Originally Posted by harry3 View Post
    It would need to be very tight, or it will gather moisture inside of it.
