Results 1 to 18 of 18
Thread: Problem Related to Oil Pressure
    VL Berlina Station Wagon
    Sep 2007
    Default Problem Related to Oil Pressure
    After running low on oil a few weeks ago ( it now has new oil and filter) it has started making a whiring sound straight after starting the car, only for about 5 seconds, then the oil pressure gauge flicks up to normal position,guage does not move imediately on start up as before.Any ideas on fixing would be much appreciated, thanks guys. Martin
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Exclamation
    Quote Originally Posted by My Car View Post
    You say low! How low ???
    Maybe some damage or now because the oil is new it's just a bit thicker to pump at start up..
    depends on if you had oil pressure when it was low...or do you mean just low on the dip stick?
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    Sep 2007
    On bottom line on dip stick.Had pressure when low,but only up to first or second notch on gauge (this is when i noticed i needed oil)Has been ok with all other oil changes,this is a new problem since running low on engine oil. Martin
    vl berlina wagon 6cyl
    Jul 2005
    find out if the VL oil filter has a non return valve, if it does, these can occasionally fail and allow the oil to all leak from the filter to the sump, causing a dry start
    also giving a false reading on the dipstick although the VL filter wouldnt contain much oil being small
    VT SS S2 A4
    Aug 2005
    Sep 2007
    Band new filter has been put in,so presumedly ok and as far as oil goes,I have always put in valvaline 20-50w with no probs.Could it have something to do with a sensor or the like. Thanks Martin
    Jun 2005
    South OZ Adelaide
    Exclamation
    Maybe the oil filter is faulty like Harry said and is the filter the same brand as before??
    Sep 2007
    Well ok,the filter is a Purolator Premium Plus made in the U.S.A. has anybody used these,different from last one I put in,cost $8.50,just the one he sold me. Martin
    the lightning
    Jun 2005
    under the Southern Cross
    is there a change in engine noise to correspond with the gauge pressure coming up? if yes then, the anti drainback valve is probably shagged.
    if no, ie engine sounds smooth straight away, then there might be an air pocket just prior to the gauge which will have to compress to a point before you get a hydraulic response from the gauge... hence the delay in gauge reading on start up. I have a mechanical gauge ie an oil line straight into the back of the gauge and had to ensure it was bled free of air before connecting up to the back of the gauge.
    good luck.
    Sep 2007
    Actually, there is an engine noise corresponding to gauge pressure.So where is the anti drain back valve to be found, and how can I check to see if operative.Cheers Martin
    the lightning
    Jun 2005
    thy're normaly built into the oil filter, most of the Ryco ones have antidrainback valves, having said that i know nothing about Nissan 6s, I'm guessing yours is a 6? but what Ive suggested would apply to all engines anyway. the other thing is correct viscosity oil, ie the oil is thicker when cold and therefore isnt sucked up through the oil pick-up as quickly by the pump.
    Sep 2007
    My last filter was a Ryco and had no problems, so I better go back to Ryco,had no idea valve is built into canister until mentioned on this thread. Now can I replace oil filter again just by leaving engine till cold, like in the morning and unscrewing,or do I have to drain oil once more.Thanks guys for all your input. Cheers Martin.
    Jun 2005
    South OZ Adelaide
    Exclamation
    Dude thats why I asked if it was a different brand, so put a Ryco 1 on and try it...
    Also the filter you said you've got on at present does NOT have an anti drain back valve, so I'd say that's you're problem..
    When the engine is cool/cold just change the filter and put some oil in the filter first..
    Sep 2007
    Sorry Mag, didnt get your drift and yes Iwill change tommorrow.where you get info.on purolator,I searched net couldnt find nowt, so thanks for that,tried to find out about valve or no valve in it.Cheers mate.Now can I take filter off without draining oil,when all oil in sump,as in when cold ,like next morning or do have to drain.Thanks Martin
  15. #15
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Look here Purolator - Pure Oil Now. Pure Oil Later. for the purolator filters
    and you don't have to drain any of your new oil..
  16. #16
    Sep 2007
    Thanks guys, all good, put Ryco filter on and gained a little more pressure too.Something to remember next time.Thanks again for allyour help. Martin
  17. #17
    commsirac is offline Banned
    vx
    Aug 2007
    So the puralator filter doesnt have the drainback valve? Thought that was something that was standard in all filters thesedays, did you "talk"/strangle to the person that sold you this brand?
  18. #18
    Sep 2007
    Yip, and he wasnt aware that it didnt havea drain back valve and there was no writing on the box either,where as the Ryco box did.He certainly is aware now.Martin
  1. Strange fuel related, half tank, right corner problem.
    By adomatt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-12-2009, 07:51 PM
  2. Oil Pressure problem on VP SS
    By ghd1996 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-08-2006, 10:28 PM
  3. Dash Lights Problem (maybe headlight related)
    By STEALTHY™ in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-07-2006, 12:30 PM
  4. Car related puns
    By Shounak in forum The Pub
    Last Post: 02-07-2006, 04:59 PM
  5. oil pressure problem i think ?????
    By krawczuk in forum V6 Development And Modification
    Last Post: 26-11-2005, 04:43 PM
