Results 1 to 7 of 7
Thread: got a few problems
    86 VLCT/ 03 II VY SS Ute
    Aug 2007
    Thumbs down got a few problems
    ok so i just got the vl coverted to manual a couple of weeks ago been going good except i found the reverse lights didnt work.. today they just came on all of a sudden and now they wont go off even if im not in reverse. any one know what it would be ?
    Also today i had to brake real hard and now my brake lights are stuck on even when the car is off.. im lost for ideas any help would be great thanks in advanced...
    Aug 2007
    fixed the brake lights one of the sensors had just fallen out and was hanging there.. still dunno about the reverse lights though.
    dijm8's Avatar
    dijm8 is offline What You Looking At
    VZ SS LS3
    Jun 2006
    wudent ther b like a switch or sumthing under the console that wud trigger the lights to go on... i got no idea correct me if im wrong... if not mayb check ur wiring
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    should be a reverse sensor on the trans some where, think right hand side this needs wiring up.
    and for brakes check the brake switch, its under the dash on the pedal box,
    the brake pedal pushes on it and activates the lights. might be broken or stuck in causing it to not turn off
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Aug 2007
    yeah i got the brakes fixed i found the switch it had just fallen out of the pedal box so it was constantly out causing it the brakes to stay on..
    i think it is wired up though because they didnt work at all before and now since i mucked around under the dash they came on and wont turn off..
    Nov 2007
    The reverse light switch for an auto is usually on the shifter and on the g/box for a manual. You will need to reconect the wiring from auto to manual.
    Aug 2007
    yep got the reverse lights workin now on the gerbox under the car the plug was just dirty and needed a bit of cleaning. all fixed can a moderator close this thread thanks
  1. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  2. VK problems - HELP!
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-04-2006, 03:25 PM
  3. vn sII into vg what problems
    By rob85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-02-2006, 08:50 AM
  4. LPG Problems
    By Shounak in forum General
    Last Post: 30-01-2006, 03:19 PM
  5. The VR of VR problems
    By Cowz in forum Electrical Wiring / Questions
    Last Post: 09-05-2005, 12:04 PM
