Results 1 to 6 of 6
Thread: coolant symptoms Have Surfaced
    VL Berlina Station Wagon
    Sep 2007
    Default coolant symptoms Have Surfaced
    I have found out what was happening to coolant transfering into rad.all the time and not going back to res. Today I found creamy stuff in radiator,under oil cap and also in reservoir,all leading up to blown head gasket and or cracked head, am i right? feedback would be appreciated thanks guys. Martin
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs down
    Quote Originally Posted by My Car View Post
    You're spot on there I'd say....
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    Sep 2007
    Ok,well repairs start from $700 up depending on whats needed, so in went some Silver-Seal,we'll see what happens now. Martin
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    I'd be getting some more quotes for your repairs, 700+ is way too much.
    New head from the wreckers/ second hand engines from a forum would be heaps less. But hopefully it's just the gasket.
    vl berlina wagon 6cyl
    Jul 2005
    someone who really knows how to use a compression gauge could give you a good idea of whats happened
    VT SS S2 A4
    Aug 2005
    Quote Originally Posted by Bax View Post
    If your taking the car somewhere for them to do the labour then it is not too expensive.
    Get them to check the cam tunnel because that is where it is most likely to crack.
  1. Any problems surfaced?
    By Pretender in forum VE Holden Commodore (2006 - ?)
    Last Post: 26-06-2011, 03:19 PM
  2. Crank Angle Sensor Symptoms
    By geta in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2010, 07:13 AM
  3. Hangover symptoms
    By drewins in forum The Pub
    Last Post: 02-04-2007, 09:29 PM
  4. Oxygen sensor.. what are the symptoms
    By Brownie1986 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-03-2007, 11:20 PM
  5. Symptoms after V8 throttle body
    By V1P_COMO in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2007, 12:17 PM
