G'day guys,
I have a problem with my motor (N/A RB30) where occasionally it runs fine but other times it misfires and carries on like a b*tch.
it usually is firing all cylinders under power
we have replaced the fuel pressure regulator.
we have changed sparks plug several times because it usually provides some relief. (then again one time it did nothing)
It is unlikely to water damage on the computer because we have shielded it. (but I'm planning on trying to try someone else's) we did reset the computer today but only provided temporary relief.
It isn't timing because we have tried multiple timings with different fuels.
possibly air flow meter?
any other ideas?
i tried to giving as much info as possible but i can't stress how intermittent the problem is.
check the rubber fuel hoses near the tank, i of the genuine hoses is no longer available and is replaced with a long length of hose that can kink partially shut then unkink later
Could be a sign the CAS is just about to die..
Also look at the ECU error codes...![]()
I was confused now I'm just not so sure!!
RIP Peter (perfect) Brock....
Check all of your vaccuum hoses to see if any are perished or split. If there is no vaccuum to the fuel pressure regulator the fuel pressure will increase making it run rich.
