Results 1 to 15 of 15
Thread: VL Brakes
    VL Calais II
    Oct 2007
    Default VL Brakes
    Hey, the brakes on my vl are a bit spongey. Seems to be a problem for a few VLs. just wondering what i could do, in terms of upgrades and how much it would cost.
    thanks
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    You can upgrade the booster and master cylinder.
    Not sure what is a straight fit but even VT/VX can be done with a little modification if you are upgrading the brakes as well. I have a VX setup for the VN, you'll either have to reflare the lines or argue with Race Brakes Sydney or Hoppers Stoppers for a month to get them to sell you line adaptors though.
    As for the brakes, i'd definitely do the rears... Look around for a disc rear end off a 5L or something and if you really want brake performance you can get a Front VT upgrade kit which is 296mm or Mr Spares does 330mm kits for just over a grand.
    vl berlina wagon 6cyl
    Jul 2005
    my berlina brakes are also very spongy i must get around to getting the system bled, in the hope theres air trapped in there
    VT SS S2 A4
    Aug 2005
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    if you pump the pedal and hear a hissing noise it will be a leaky master cylinder.
    ========My Statesman 20's Mafless and 3.9's========
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    the brakes in my vk are really spongy untill i pump them a few times then they go back to normal. would this be the brake booster/master cylinder or just too many vacuum leaks lol
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Quote Originally Posted by mitch1234 View Post
    thanks
    upgrade in brakes for a vl is set up depending how far you want to go.
    a simple swapping of a calais disc rear end will help reduce the sponge a bit and increase the braking force,
    swaping the front disc and calipers for the turbo or v8 set up,
    if you can source one or afford a new 1" master cylinder (turbo/v8 master) this will also be of a huge gain in solving the pedal travel.
    basically that is the best set using the stock part avalible.
    then you can use the vt front disc and caliper if your really after a performance improvment.
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Feb 2006
    Radelaide
    cohn's Avatar
    cohn is offline VN28CN
    VN Calais Turbo
    Nov 2004
    Penrith
    Quote Originally Posted by VK_308 View Post
    That means there air in the system, so it needs bleeding.
    Soon to be back on the road, Turbo VG.
    Oct 2005
    youd need the vt hubs too
    yes i forgot to mention the hubs are diff, can buy hub adaptors for about the 250 mark,
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    vt upgrade kit is what you need! will set you back from $750.00 if you fit them and more if you get them fitted.
    Nobody wants to play with me
    Nov 2007
    Default brakes
    cheap upgrade for vl turbo brakes (not standard vl brakes) is to use holden hz to wb brake pads
    they have more grip as they are bigger pads .only mod required is to grind down the metal backing plate same size as the turbo backing plate
    beat that, only for the cost of pads,
    '04 Holden VY II SS
    Dec 2007
    if they're still spongy give em a bleed. just did it on my VL last week and now i have crisp response on them. and yeah in regards to an upgrade, go vt brakes (twin piston fronts and single piston rears) or look into r33 brakes (4 piston fronts and twin piston rears)
    Quote Originally Posted by Urban Dictionary
    sheepy:
    Person that is deemed utterly useless most often due to a hangover and is in need of a "sheep" herder
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Will my VR brakes fit onto my VL? Because I want to upgrade my VR to VT brakes...
  15. #15
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    i have a VL 5L disc brake rear end for sale. it's in sydney at a mate's house. i also have a 1" master cylinder new in the box if you want to buy that too.
  1. VZ HSV brakes
    By GROWLZ in forum General Discussion
    Last Post: 17-11-2009, 04:32 PM
  2. brakes help!!!!!!!!!!!
    By vn_lexcen_s2 in forum General
    Last Post: 06-09-2006, 12:24 AM
  3. Brakes
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-09-2006, 09:55 AM
  4. VK brakes
    By brettyb2002 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-05-2006, 08:01 PM
  5. Brakes
    By mitch01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-11-2005, 03:45 PM
