Results 1 to 9 of 9
Thread: Few Problems - Idea's Needed
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Default Few Problems - Idea's Needed
    My car is dieing. Its got a multitude of problems, and i just need a few ideas as to what may be causing the problems.
    List is as follows:
    -Bad fuel economy - About 18L/100km
    -If i apply the throttle on about 2%, the rev's drop and it feels like its going to stall, but never does
    -On acceleration, it is blowing black smoke and leaving deposits all over the rear of the car.
    Any idea's would be appreciated. I've got both Gregories and Max Ellery manuals but havent had a chance to go through them to diagniose the problem.
    Thanks In Advance
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Air flow meter? Common problem. Does it have any leaks? Give that and the piping a wiggle and see if the revs change at idle. Also wiggle the plug that goes into it.
    Have you done a timing belt recently? Is it on the correct teeth? Or is it old and stretched? That will throw the cam timing out and may cause similar symptoms.
    Have you done a code check?
    Visit my Facebook page
    Sabbath''s Avatar
    Jul 2006
    I have two air-flow metres, might change it out tomorrow to see if that helps.
    Timing Belt was changed when i fixed the rear main seal about 12 months ago, but the car was never properley tuned up after that, but has been running perfectly up until the last month or so.
    Havent done a code check yet, going to get onto that tomorrow morning.
    Just an update - The exhaust fumes smell oily
    Sabbath''s Avatar
    Jul 2006
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    black smoke means its over fueling... maybe your injecotrs need a good looking at
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Check the fuel pressure regulator. If the vaccum hose falls off or leaks it will raise your fuel pressure so your engine will run rich.
    '87 VL Calais with L67
    Aug 2007
    id say its most likely your oxygen sensor.
    when they fail they run rich as a default to protect the engine from the high temperatures of a lean burn.
    that would be the best place to look
    HZ Sandman Ute, HZ GTS, VT Senator
    Apr 2006
    yeh sound running rich. if you want any injectors let me know or a )2 or anything else lol.
    cheers
    jason
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Did you end up sorting this problem out DARKVL? If so let us know what it turned out to be... I'm curious as to whether it was just a simple fix
    WTB: mulberry VN interior parts
  1. Advise needed and problems with my VN
    By mickah in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2007, 09:50 PM
  2. urgent help needed - idle problems
    By vnbelina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-07-2006, 04:57 PM
  3. Temp Sender Problems, Help Needed!
    By brendo22 in forum Electrical Wiring / Questions
    Last Post: 07-05-2006, 04:13 PM
  4. Battery Problems - Help Needed
    By hsvp57 in forum Electrical Wiring / Questions
    Last Post: 07-05-2006, 12:06 AM
  5. Help needed! Engine problems
    By shaggerz in forum General
    Last Post: 06-11-2005, 11:43 AM
