Results 1 to 6 of 6
Thread: Testing in-tank low pressure pump
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Default Testing in-tank low pressure pump
    As above, has any1 ever tested their in tank pump??
    Tell me what happened as mine passed the test but had a strange way of doing it..:my:
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    vl berlina wagon 6cyl
    Jul 2005
    Jun 2005
    South OZ Adelaide
    Arrow
    Quote Originally Posted by harry3 View Post
    what happened?
    mine started to make a strange noise so I replaced it
    Hey Harry I was told the test was to run the LP pump just as it comes out the tank and the flow test should be 1lt in 30secs and it did that but it would start then slow to a trickle then full flow again...
    Next day I tested it for a longer time and it did the same as b4 but got slower and slower until it stayed a trickle, so put in a new one..
    Jul 2005
    a remote possibility is the filter bag on it becoming blocked by sediment but I think eventually all these electric pumps simply wear out
    a retailer said a common cause of a near new pump failure is sediment blockage and the pump people generally wont give any replacement until they have cut the pump in half to see if its blocked by sediment
    Jun 2005
    South OZ Adelaide
    Yep spot on Harry and they recommend that the tank be removed and cleaned 1st..
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    My in tank pump got replaced the other day, I was talking to the mech and he pulled the pump out to check it. And she was routed.. The filter bag and everything was missing completely.
    But yes, that doesn't help, sorry.
  1. Pressure in fuel tank
    By groucho in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-04-2007, 01:09 PM
  2. Testing a Fuel Pump...
    By m3taL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-09-2006, 06:37 PM
  3. No air pressure for fuel tank
    By Richo2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-01-2006, 02:53 AM
  4. LPG Tank Testing
    By The VHK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-01-2006, 05:14 PM
  5. Fuel tank pressure
    By vsv8berlinawag in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2005, 10:39 AM
