Results 1 to 6 of 6
Thread: Auto Gear shift problem?
    VL
    Nov 2007
    Unhappy Auto Gear shift problem?
    Hi all,
    My VL wagon has started only shifting gears at set points 40ks 1->2, 70ks 2->3 etc.... this started out of the blue?
    I am now using sh1t loads of petrol and need to fix it ASAP.
    Any help is welcomed..
    2h1bb1....
    VL
    Nov 2007
    VT SS S2 A4
    Aug 2005
    Have you had it serviced recently? How is the oil level and what colour is it?
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Check to see if the hose has fallen off the vacuum modulator. It is towards the rear of the trans on the left side and should run up to the inlet manifold. Sometimes the vacuum modulator can get a hole in the diaphram, which will cause the trans to shift abnormally and the trans fluid will get sucked into the engine through the vacuum hose and then burnt in your engine so it blows smoke. To check if the modulator diaphram has a hole in it you just pull the hose off the modulator and if any trans fluid runs out of the hose the diaphram is leaking and should be replaced by screwing another modulator in
    VL
    Nov 2007
    VL
    Nov 2007
    Tree cutter, .
    It was the connection to the inlet manifold .
    Looks like there has been a bit of DIY there in the past .
    Thanks for the help.
    Best Regards,
    2h1bb1...
  1. Gear Shift On An Auto,
    By Terence in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-04-2009, 05:30 AM
  2. 3rd to 2nd gear shift
    By mina_783 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-10-2007, 01:51 AM
  3. Auto Gear Shift Knob
    By sgo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2007, 05:05 PM
  4. Gear shift linkage? What?
    By Scooter79 in forum General
    Last Post: 19-08-2006, 09:54 AM
  5. Poor auto gear shift on VC
    By SNOWcondor in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-09-2005, 09:52 AM
