Results 1 to 4 of 4
Thread: vl Headlight Problems
    1988 Holden Commodore Vl GTS
    Nov 2007
    Default vl Headlight Problems
    howdy yall. i am the lucky owner of a 1988 vl gts rb30 . now the curent prolem i have it that both high and low beams are on the same switch, like when high beam is on both lights are and when high beam off no lights. it is very strange to me and it is starting to **** me off. i have the melted fuse rail symdrome also could that be a factor? any help would be appretiated. cheers
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    park and low beam are the twist switch on the end of the indicator stalk.
    high beam is activated when the indicator switch is pulled toward the steering wheel and will only stay on when the low beam is on.
    they are seperate switches.
    Nobody wants to play with me
    vl berlina wagon 6cyl
    Jul 2005
    each headlight should have a double filament globe that gives either high or low but not both together
    also a single filament globe that gives high only
    also a parking lamp globe
    a common problem is the silvering peeling off the reflector due to heat
    Dumped IRS VS Acclaim 3.8, VR Stato Caprice 5.0
    Nov 2007
    Hatton Vale. country at its best. :)
    it means you have a melted fuse rail. you can fix the problem by connecting the high beam to a single fuse and the low beam to a seperste fuse also. i found that with my vl, and my bro fixed it like that as he is auto elec
  1. VZ Headlight
    By Luke0011 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 31-01-2008, 09:32 AM
  2. how much should i pay for a new VS headlight?
    By nickdanger in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2007, 08:42 PM
  3. VL headlight problems
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-12-2005, 07:57 PM
  4. Headlight
    By luvmycommodore in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-11-2005, 02:36 PM
  5. headlight
    By robcom in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-11-2005, 08:13 PM
