Results 1 to 9 of 9
Thread: Dash removal for new cluster
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default Dash removal for new cluster
    Hey guys, anybody have the hot tip on how to remove the dash so i can get to my cluster?, i wanna do a swap for a tacho setup.
    What part of the car do i wire up the tacho? since i dont have the original loom connection for it..
    Thanks
    Goon
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    It's quicker then your mothers VN
    Sep 2005
    At the time of this post, under your mothers bed with my laptop
    its a straight swap
    from memory
    undo your whipper switches and your demister switch
    then undo the top part of the dash
    then theres 4 screws/bolts that hold the dash in undo them
    then theres 2? i think plugs + speedo cable to remove
    then just reverse
    Goon's Avatar
    Feb 2006
    GC. QLD
    Thanks heaps man, ill give it a go soon
    Goon's Avatar
    Feb 2006
    GC. QLD
    Anybody have an idea on way my tacho is showing lower revs below 0 ? it go's above 1 using pwr mode.
    manualwagon is offline manualwagon
    Vl manual wagon, VS Statesman, 2007 Triumph Tiger.
    Jan 2007
    Mooroopna Vic
    Hey goon. Read my thread about fitting a tacho/calais dash, it give clear tips, especially regarding the oil pressure sender. the gauge sender id different to the light sender, so is the wiring on the back of the dash. John
    Jan 2007
    Mooroopna Vic
    Default Dash
    Me again goon! The thread i posted was titled "fitting Calais dash to exec", to find it you have to scroll down to the bottom of the VL page then click on the box that has 1 month in it, when it drops down pick 2 months then click on show threads, the thread is about 3/4 of the way down the longer page. John
    Goon's Avatar
    Feb 2006
    GC. QLD
    I found your thread mate, it still didnt explain what i wanted, unless i read it incorrect...
    I still cant get this tacho to idle the way it should, its like it has a crap signal or something... Should there be a wire coming out of the tacho that go's to somewhere on the cluster setup? maybe the loom?
    Goon's Avatar
    Feb 2006
    GC. QLD
    Okay so i had a read around calasisturbo and found something about a brown with a red strip wire? on the dash loom? and one in the engine bay area?
    Anybody be able to say if im on the right track?
    im sure ive got a 6 cylinder cluster....
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    mine was a straight plug in job and it all worked fine. I did use the top cluster loom that came with the cluster tho. my cluster was from a manual car and mine is auto, the only thing i had to do was swap the speedo for my auto one because the manaul cluster does not have a speed sensor to plug into for the auto to kick down. (would change up but never down)
    ========My Statesman 20's Mafless and 3.9's========
  1. VR/VS - Dash/Instrument Cluster Removal & Replacement
    By NKX in forum Holden Commodore How-To's
    Last Post: 30-12-2010, 07:06 AM
  2. Help Dash Removal!!!! VX S PAC
    By steveo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-10-2007, 09:32 AM
  3. Swapping VR L2 dash cluster with VS Stato L3 Cluster
    By wheredoesthisgo in forum Electrical Wiring / Questions
    Last Post: 07-04-2007, 03:28 PM
  4. dash removal
    By just-o1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-10-2006, 04:09 AM
  5. Replace VN dash cluster with VX dash cluster
    By Xalies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2005, 06:55 PM
