Results 1 to 18 of 18
Thread: Vl Missing and fart'in
    VL
    Jul 2005
    Default Vl Missing and fart'in
    G'day everyone any help would be unreal. me vl's running rough as i had a mechanic look at it and of course on the day it decided to work fine and worked fine for bout a week. then i get half way down the shops the other day and it does the same thing. Ill start it up and it might sound good for a sec then it goes a little rough, give it rev and it shakes around heaps and just sounds like it dont wanna go. there was a bit of black smoke coming out the exhaust. so yer any ideas or suggestions would be awsome.
    cheers.
    VT SS S2 A4
    Aug 2005
    vs calais eco
    Sep 2006
    Disney land!
    fuel pump on the way out?
    does the fuel pump sound noisy?
    if theres black smoke from the exhaust and it running rough i would be sus on the o2 sensor! but there not cheap as i got a price for one yesterday @ $155 from repco and $130 from supercheap!
    hsv ss
    Feb 2006
    VL
    Jul 2005
    Cheers for that i mucked around with the screw on the AFM, my idle srew, did a diagnostic test and cleaned all my connections up and its going bloody perfect. So im hoping thats it.
    hsv ss
    Feb 2006
    good to hear mate .......sometimes also a blocked cat will cause similar problems
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Quote Originally Posted by Moff View Post
    how does one know if there cat is blocked?
    Wheres this screw located? and how do u tune it?
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    hsv ss
    Feb 2006
    take your car to an exhaust joint thats what i did they will find it very quickly if its blocked to test an afm just get another one of a mates car or borrow one and try it on yours easiest way! its only like four allen key screws i think
    Nissan Silvia S13 RB30E+T
    Oct 2009
    hrmmm im having same problem ... anyone know what the test voltages on the afm shud be ?
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    unbolt the cat from exhaust 4 bolts and inspect.
    easy.
    i had this prob a month ago, took my car to a property i go shooting on...killer driveway/dirt roads not good for a lowered car, but hey its a HOLDEN
    while leaving the car sounded quiet with no power.....
    wacked the cat and heard bits moving around inside as i suspected i had smashed the internals(honeycomb porceline crap whick blocked my exhaust)
    got home unbolted it and found my problem
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Quote Originally Posted by S13 Silvia RB30E+T View Post
    between 1.26V which is lean and 1.32V which is rich base settings
    Just for interests sake
    3.6V is factory which is lean and with 2.0V Being rich
    dude set it to 3.5V(resistance is 375 ohms)
    or set it off the ECU holding engine at 2000 rpm adjust untill both LEDS are flashing together
    warm engine..
    premium's Avatar
    premium is offline P-Plater
    1988 VL Berlina, 1985 VK SL
    Sep 2009
    Williamstown, VIC
    Like my father always told me, start small and work your way up, try things like the spark plugs and leads first, before doing something like unbolting the cat or changing your AFM.
    Quote Originally Posted by premium View Post
    high-performance sunroof?
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    have you checked the ect sensor blowing black smoke could be running rich due to the ect giving incorrect engine temp to ecu common problem on vl's due to corrosion check for air leaks behind the air flow meter
  15. #15
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
  16. #16
    vl
    Nov 2009
    Default vl backfired and now it has no spark
    it is on lpg and has had a backfire on the previous owner . i have just got the car home (on a trailer) and am trying to fix . i have found it has no spark
  17. #17
    Nackerz's Avatar
    Jul 2009
  18. #18
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    why are we repeating this in another thread...
    use your search, all we seem to do on here is repeat and repeat.
  1. VS missing
    By VSIIBerlinaL67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-12-2006, 04:18 PM
  2. missing
    By ab56452001 in forum Electrical Wiring / Questions
    Last Post: 25-11-2006, 06:46 AM
  3. VT missing
    By horndog in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-06-2006, 09:49 PM
  4. Vt V6 Missing Still !!!
    By badly_drawn_boy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-04-2005, 11:42 PM
  5. vt v6 missing !
    Last Post: 18-02-2005, 11:35 AM
