Results 1 to 7 of 7
Thread: Ticking sound from brake booster after car is turned off??
    vs calais eco
    Sep 2006
    Disney land!
    Default Ticking sound from brake booster after car is turned off??
    i have just bought a unregsted vl calais n/a rb30 ect, and its been sitting in a shed for about 2 years! the prob is that the brake fluid was low (but not empty) and everytime the car has been started and then turned off there is a ticking sound that comes from the booster? any help would be great!
    p.s the car being unregsted has not been driven on the road so i cannot say the brakes work real well but they seem to pull the car up when moving it around the yard and into the garage ect..
    vs calais eco
    Sep 2006
    Disney land!
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The ticking could be the vacuum bleeding down after switch off. Having sat for so long, the shaft that goes into it could be a bit rusty and sticky, and any movement could cause a tick.
    Visit my Facebook page
    vs calais eco
    Sep 2006
    Disney land!
    Quote Originally Posted by Not_An_Abba_Fan View Post
    cheers for the info
    i called up brakes plus and he said he had no idea? and the brakes seem to work alright so will see how she goes when its back on the road!
    Dumped IRS VS Acclaim 3.8, VR Stato Caprice 5.0
    Nov 2007
    Hatton Vale. country at its best. :)
    id do what not_a_abba_fan suggested and check the shaft in the booster to make sure there is not rust, if there is youll need another booster.
    vs calais eco
    Sep 2006
    Disney land!
    if i had to replace the booster, could i just do the vt upgrade? e.g go to the wreckers and pull a vt v6 booster of another commodore and bolt it up to the lines already on the car? (probably wishfull thinking:P)
    Nov 2007
    probably not a good idea as it is designed for the ABS try and get one from a vn-vp instead
  1. VT II Brake Light Comes on when Headlights are turned on.
    By chrisrigney in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-12-2007, 05:19 PM
  2. VT II Brake Light Comes on when Headlights are turned on.
    By chrisrigney in forum Electrical Wiring / Questions
    Last Post: 30-11-2007, 10:53 PM
  3. Brake Booster
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-10-2006, 09:24 PM
  4. Leaking Master Brake Cylinder Connecting to Brake Booster Advice help please.
    By IceDHB in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2005, 02:32 PM
  5. Strange sound when Air conditioner is turned on
    By clinker1212 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2004, 11:33 AM
