Results 1 to 9 of 9
Thread: Turboing the N/A VL, help please....
    HSV VP Senator
    May 2006
    3rd planet from the Sun...
    Default Turboing the N/A VL, help please....
    Hi there all, I have bought the gearbox for the turbo, next on the ajenda is a diff centre.....(what sort should I go for...?)
    Also is the tailshaft from the n/a the same as the turbo?
    I will also be running straight gas........so has anyone done a setup like this before running either dual fuel or straight gas??
    Thanx for the help so far guys..........
    Lets work as a TEAM and do it MY WAY!!
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    go buy a vlt diff dont bother with messing around with the n/a diff as it only has 25 spline axles as where the vlt diff has 28 spline axles ....and both have the same gear ratio 3:45
    tail shaft is the same im pretty sure aswell
    look up a vl commodore called GAS747 he runs straight gas and is in the low 11s i think
    calaisturbo.com.au - Powered by vBulletin will have all the info your after
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
    It's quicker then your mothers VN
    Sep 2005
    At the time of this post, under your mothers bed with my laptop
    crazywog's Avatar
    crazywog is offline VS V6 ECOTEC KING
    my fully shick holden bro
    Oct 2006
    In my fully shik holden bro
    VLDAVE, its GAS747 and hes making 10's atm just a correction there mate.
    RAJAB RACING
    FullBOOST
    PRESTON AUTOMATICS & DIFFERENTIALS
    etstreet.com
    Soon to own a vb or gemini
    Jan 2008
    just change ur diff mate dnt worry much bout the shaft i dnt think it really makes a difference not unless ur gonna run in the low 10s and 9s marks
    XTC16's Avatar
    XTC16 is offline Certified Wise
    Foot Falcon
    Apr 2006
    Brisbane - South Side
    GAS747 is Pauly and he runs consistent 10's.
    This is his car at the front
    [GMJ37] Another Commodore .... another dollar ....
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    I have a V8 rear end for sale. same size axles as the turbo rear end. just different diff ratio. i was going to put a diff centre out of a falcon in it and they are 3.7 ratio. it's in sydney if you want to buy it.
    bolby's Avatar
    bolby is offline werd
    VH SLE 202 turbo
    Apr 2006
    endeavour hills, melburn y0
    as others have said
    VLT dif will see you safely through. just get it reshimmed and what not if its in bad shape.
    and dont even bother with dual fuel lol no good!
    gas can definatly be done and its been proven. it may take a lil more boost to get there but its not impossible
    will need a tank with twin outlets (or 2 tanks or a single tank with a outlet mod) with twin gas lines and twin modified B2 converters to a gas research throttle body, at least 440cfm in size
    thats it for the gas system!
    which is what ill be using but ive got a 480cfm t/b
    bolby's Avatar
    VH SLE 202 turbo
    Apr 2006
    oh and theres also plenty of people pushing upto 20psi through the stock n/a bottom end on a safe tune, so that can also be done
  1. Turboing a vl
    By Vlturbo07 in forum The Pub
    Last Post: 04-12-2007, 06:46 PM
  2. turboing VH 202
    By big viv in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-05-2006, 04:28 PM
  3. Any Chance For Turboing
    By goughie_69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2006, 09:14 PM
  4. TURBOING my vl
    By Cherrys in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-11-2005, 04:47 PM
  5. Twin Turboing VS
    By Grimey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2005, 01:26 AM
