Gday,
My VL has issues whenever I take it for a longer drive or even a short drive in summer. It wont start after I shut it off - but if I wait awhile it starts again.
I'm thinking its Fuel vaporisation, because when I try to start it when its hot it will make pumping noises but wont kick.
I'm kinda new to all mechanical side of things, but I understand that the VL has 2 fuel pumps and one is in the actual fuel tank...?
How much would it be to get the two pumps and the fuel lines replaced?
Unless anyone knows that it is another problem.
Cheers.
the internal pump is about $80, external about $180-$200.... would also be worth getting your fuel pressure regulator checked out first cos if thats playing up there wont be enough fuel pressure in the rails to properly atomise when injected into the cylinder
Get the Crank Angle sensor checked out. They always **** up on VL's. It would be wise to get it changed over now anyway as it will soon stuff up and leave you stranded at the lights....
1988 VL Berlina turbo 5 speed
http://forums.justcommodores.com.au/...ml#post1446411
1987 VL SL turbo 5 speed ~STOLEN~
http://forums.justcommodores.com.au/...ed-manual.html
if you can hear the pumps working then there ok ? but for a new bosch pump about$230 inside pump 140-150 use a bosch pump i had probs with others
a possible cause is kinking of a rubber fuel hose, have a look at the back of the fuel tank and see if theres a long length of rubber hose, the original hose is no longer available and holden recommends replacing it as above
problem is this hose can kink shut from heat coming back from the engine softening the rubber, the engine stops but after a while the rubber cools and the hose unkinks itself, the cure is to support the hose by running it thru a wider tube so it cant kink
if you cant see what Im getting at, think of a garden hose where the water stops when the hose is bent back tight
