I Got A VL Commodore And I Need A Fuel Pump I Just Need To Know How Or If I Can Tell If It's The External Or The Internal One I Need!!!
wots your car not doing first mate? who told you it's the fuel pump?
It's not getting any fuel upto the carbie and i can't hear the fuel pumps making any noize
my fuel pump is making a strange gurgling noise when u start the car its the outside one so im gonna change that but u said its not getting up to the carby isnt ur vl fuel injected
just wondering
to the carby? is it just an rb30 motor? anyway if its not making any noise- your thinking of the external one, just replace it- check your relay to see if it's working, do this by swapping and changing with the other relays that are there- if that doesnt help make sure you put all the relays back to where they were.
have a look at you fuel pump its at the front of your tank under the car closest to the motor. just check the plugs are on correctly and then- if it still no go REPLACE
also where do you live- i have a spare fuel pump you can try
