Results 1 to 5 of 5
Thread: rb25 head on rb30
    starfire vc's Avatar
    starfire vc is offline now on 10 pound
    VL turbo, RB30ET VH wagon, 64 EH in the build.
    May 2007
    Brisbane,North
    Default rb25 head on rb30
    howdy all. managed to pick up an rb 25 head for 100bucks, my question is who out there has done this conversion to there vl?
    I just want to clear a few things up before i start pulling things apart.
    will the rb25 head bolt straight to the rb30?shud i use the rb25 ecu? can i use my inlet and exhaust manifolds. any info appreciated
    the germans designed it, the aussies built it, the japs got it moving and the wogs got it dosing...
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    I think depending on the head there might be an issue with an oil/water line, from memory?
    you will need the rb25 manifolds.
    you'll also need to get creative RE: the ecu - as the rb25 head doesn't have provision for a distributor (which is what the vl ecu uses to get a crank/cam position signal, and uses for ignition)
    As far as i'm aware the rb25's run a multiple coil setup.
    There's a slight modification to the block required for a 2nd timing belt tensioner (just a hole drilled and tapped)
    there's a site somewhere around detailing the conversion in pretty intricate detail. - google for it
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    for non turbo applications put the head on. if you are going to turbo then don't put the head on, stay with the single cam head, it'll have better air velocity. I researched the arse out of this idea for myself.
    Mickey Maj is offline VLT RB30DET
    VL Commodore
    Aug 2005
    hey guys hopefully this will be of sum help cant remember wot site i found it but there is a lot of useful info in here.
    Attached Files Attached Files
    May 2007
    Brisbane,North
    thanks 4 that sum good info in there....
  1. Rb20, Rb25, Rb26, Rb30..... ?
    By Marco-EFIVL in forum Straight 6 Development And Modification
    Last Post: 30-12-2009, 12:40 PM
  2. rb25 head worthwhile?
    By bangers in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-01-2007, 05:48 PM
  3. rb25 head
    By kunifa in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-03-2006, 11:04 PM
  4. rb30 head
    By Jules86 in forum Swap / Wanted to Buy / Trade
    Last Post: 28-08-2005, 02:34 PM
  5. Rb25 Head On Rb 30
    By \\SaM// in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-04-2005, 01:33 PM
