Results 1 to 7 of 7
Thread: Air Flow Meter is it faulty?
    VN Executive
    Sep 2007
    Default Air Flow Meter is it faulty?
    Ok my car has been suffering massive power loss and it's getting dangerous in situations like overtaking.
    Straight after a gear change it seems as if the car takes a few seconds to kick in.
    When it kicks in the power isn't even instant, the power kind of comes and goes real quick and then it's there.
    It's more noticeable when I put my foot down but it's still there either way
    If I keep the car revving high on gear change it seems to be better than changing gears and driving at a normal pace.
    I've been told it could be the air flow meter, We started the car and let it idle, we then unplugged the airflow meter and it dropped idle a bit then seemed to recover but we think it was a tad quieter than when it was plugged in.
    Please help it's driving me insane and I want my car to run as it should!
    86 VLCT/ 03 II VY SS Ute
    Aug 2007
    hey mate i had this same problem with my calais, i tried udjusting the AFM and was fine for a while then ***ed up again, replaced fuel filter and got fuel lines cleaned same thing again. it could be a range of things never figured out what mine was as its siting in the shed at the moment due to other problems but somethings you shuold check are CAS (Crank Angle Sensor), fuel filter and pump, AFM thats just a few i kno of sure there are more things. its kind of a trial elimination thing just gotta do them all till you find which one it is
    vl berlina wagon 6cyl
    Jul 2005
    it helps if you can get a loan of an AFM from a friend who also has a VL with the 6cyl motor
    an autoelectrician could, I think check it for you,you should check the plug for any corrosion also a shot of contact cleaner to the sensor is worth trying
    wonder if it might be a blocked fuel filter?
    KRUPTD is offline VN BT1 5L
    VN BT1 5L,5spd,LSD
    May 2007
    Griffith, N.S.W
    Check your fuel pressure/flow mate,VL's have 2 fuel pumps an inner and an outer.I replaced recently an inner fuel pump on a VL turbo having similar symptoms to what you have mentioned.But when checking your fuel pump pressure also check the flow,you can have good pressure within specs but if the flow isnt there or hasnt got enough it will not supply enough flow to your fuel injectors and create poor performance.cheers
    Vp calais, gemini
    Feb 2008
    melb, vic
    if your afm is faulty i have one at home that has been checked (and wat ever else they do) and stamped year 2000 it come of my vl paddock bomb before i got rid of it, aparently it was a reco? so i keeped it if your interested in it, im in melb! cheers
    vn v6 calais mock up run around,
    vn v6 manual wagon parts car,
    vp v6 berlina lx project car
    vc 186 aussie 4 speed
    vl 6cld wagon
    HZ Sandman Ute, HZ GTS, VT Senator
    Apr 2006
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Lightbulb
    Quote Originally Posted by Mordred View Post
    1st run a ECU test and see if any error codes show up
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
  1. Vt air flow meter
    By bordi1983 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-02-2006, 11:22 AM
  2. Air Flow Meter Help
    By Statesman94 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2005, 11:01 PM
  3. LS1 air flow meter
    By I LIKE COMMODORES in forum General
    Last Post: 01-09-2005, 02:43 PM
  4. Air flow meter...
    By stylen in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-06-2005, 02:03 PM
  5. vl air flow meter
    By psi berlina in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-06-2005, 09:07 PM
