Results 1 to 20 of 20
Thread: Damn fan belt
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Default Damn fan belt
    This is giving me the ****s, much like the glovebox.
    My fan belt is intermittently noisy. I checked it the other night and it was tight, hardly any play when I pressed down on it. So I loosened it, noise went away - but came back - generally only when cold/under revs.
    So what are we leaning towards, belt still not right, or maybe the bearings in the pulley are rat crap. I just assumed if it was the bearings they'd be going constantly? Not just under high revs and when cold.
    Someone tell me.
    And is there a correct tension on the belt?
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    commsirac is offline Banned
    vx
    Aug 2007
    candle wax rubbed over it is a remedy ive heard...
    Do you have a clutch fan? Generally the first rev out when cold still has the fan under minimum slip(maximum load on the fan belt). It may simply not squeak when hot due to no load being on it, as well as the problem of the distance between the pulleys shrinking just a little when the motor is cold(more than the fan belt itself will contract as it never gets as hot as the motor)
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    is the rubber hard, if the rubber is hard it time to say good bye, try to use some sticky spray on lubricant
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VP Exec,Gsx-R 750
    Mar 2005
    Why not just put a new belt on? In my opinion, if the belt has worn in the "V" to the point where adjusting the belt will not reduce slippage, why not just throw a fresh belt on there?
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    do you have 1 belt or 3 belts ? a bottle of water with a small hose attached and poor it on each belt when the noise is there the noise will go away this will tell you which belt or pulley is making the noise.
    then, a new belt/pulley, tension, or BELT GRIP, belt grip is a bit messy so if like a clean engine do not use it!
    Nobody wants to play with me
    Bax
    Nothing
    Jan 2004
    QLD
    Okay, answering questionis. 2 Belts - definitely know which one it is.
    It's a new belt.
    I've tried candle wax.
    Have a clutch fan, it's brand new.
    I think that's all of them.
    I might just go grab another new belt anyway just in case this one is glazed. But I'm a little confused as it's been on there a week and started squeaking.
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    ive been taught by the old man to use salt besides the soap and wax etc
    if the belt has absorbed moisture the wax and sprays wont do anything, sprinkle a little salt on the inside edge of the belt so its squashed into the pully and belt,
    this will asorb the moisture out of it and should stop the sound,
    give it a shot but dont go poring a kilo of salt on it, a pinch or two will be fine
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Bax
    Nothing
    Jan 2004
    QLD
    Cheers I'll give it a go tonight, I'll more than likely take it back to the mechanic tomorrow and tell him to fix it if it's still going.
    Thanks.
    vl berlina wagon 6cyl
    Jul 2005
    'dry lube' can help but is the top of the belt sitting down in the pulley groove? if so its the wrong size belt, the top of the belt should be slightly higher than the top of the groove in the pulley
    vx
    Aug 2007
    Quote Originally Posted by Bax View Post
    It's a new belt.
    Ive found new belts have a higher tendency to squeak, and if you have a brand new clutch fan, its going to be putting a much higher load on the belt when cold than the old one. If you say rev the car out to 3000rpm when it is cold you probably hear the squeak? and it continues to do this on every gear change? Try holding the revs at that level or higher for at least 15 secs and see if this unlocks the clutch fan(if that is the what happening).
    Its also possible that the clutch fan you have installed is defective......ie it operates at minimum slip all of the time.
    Personally, I never take an engine over 2000rpm until the temp gauge is in the normal range.
    '87 VL Calais with L67
    Aug 2007
    Quote Originally Posted by harry3 View Post
    sorry mate, no way. either flush with the v groove at the highest. usually the correct belt will fit 1mm or so below the v ridge on the pulley. you run the risk of the belt being thrown if you have it sitting above the v groove in the pulley because there is less area to guide it.
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Thumbs up
    Quote Originally Posted by VL Berlina 5speed View Post
    Yep sounds strange but Sean told me this a good while back and it does WORK
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    VL 5speed commie
    Mar 2008
    if you have changed you belts and it still slips. take you v-pulley off and cheack the sheaves for wear run a datum edge on the inside of the v-pulley sheave hold it up to some light and see if it is worn. usally if the v-pulley is worn the belt wont grab it will just slip untill the belt gets hot and grabs.
  15. #15
    maxpower QLD's Avatar
    maxpower QLD is offline has mild super powers
    Xtrail/5spd VL
    Feb 2008
    QLD (the police state)
    Hey there fellas . I'm not sure if this will help or not but have u tried changing the cluch and fan ? for the past week the clutch in my fan was sqealling like a mother f....er and at first my friends and i thought it was a fan belt so i replaced it with a new one and it still sounded the same so i swaped the fan with the one in my other VL and it fixed it . No more noise . Hope that helps
    Quote Originally Posted by VS Omega View Post
    "gonna beat you to the next set of lightes uleh"
  16. #16
    Bax
    Nothing
    Jan 2004
    QLD
    Just picking off a few of the above points, pulleys I haven't checked but I'm near positive that they're clean, they did have surface rust but that disappeared with the first belt. I'm on my second belt now and still noisey. You can tell when the belt squeaks and the pulley squeaks though, its a different noise.
    New clutch fan too unfortunately.
  17. #17
    Xtrail/5spd VL
    Feb 2008
    Hmmm ok then well if you've instaled a fresh fanbelt the only other things that i can think of would be
    1. check the other belts like the
    aircon or power stearing belt posibly ?
    2. bearings in alternator,water pump, power
    stearing pump,bearing in aircon belt tentioner
    I had the same problem with my XR6 before i sold it . I ended up replacing every belt , bearing , tensioner , that was on the front of the engine with new parts . It was a costly prick of a job but it fixed the problem.
  18. #18
    Bax
    Nothing
    Jan 2004
    QLD
    I guess my question is how hard is it to replace the bearings.
    I've only got two belts on there at the moment as aircon isn't installed. I'm thinking about taking the power steering belt off for a few minutes to see if stays. But I'm 100% positive that it's the power steering compressors pulley.
  19. #19
    Xtrail/5spd VL
    Feb 2008
    The bearings in the alternator are easy if u have a few tools handy as for the power steering pump well it would be cheaper to get a good second hand one as i've never really had a go rebuilding a nissan one. If you suspect the power steering pump is the cause then take the belt off and take it for a drive otherwise take all the belts off and check the bearings on water pump , power steering pump and alternator pulleys for excessive movement .
  20. #20
    Xtrail/5spd VL
    Feb 2008
    The pulleys should spin freely when spun by hand ? well the ones on both my VL's spin freely .
  1. Damn sub box!!!
    By matty88 in forum Car Audio
    Last Post: 21-12-2010, 07:16 PM
  2. Serpentine belt (Acc Belt)
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-02-2007, 12:12 PM
  3. The G** Damn Rattle
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-11-2005, 04:55 PM
  4. Damn Insurance
    By GrubSport in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-11-2005, 10:39 PM
  5. Damn car
    By JJ66 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-05-2004, 08:12 PM
