Results 1 to 16 of 16
Thread: v8 rotors & calipers on 6 cyl
    dan_man31's Avatar
    dan_man31 is offline now projecting oh yeah :D
    vl executive
    Feb 2005
    brisvegas
    Default v8 rotors & calipers on 6 cyl
    will bigger rotors and bigger
    v8 brake calipers fit onto a standard vl 6cyl strut
    it seems that the 290mm rotors dont want to fit with the v8 calipers on my strut
    ARE they different ???????????
    need help asap
    thanks Dan
    Its Stock And it Rocks .... ditch the bitch lets go racing
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    you'll need the v8/turbo rotors to fit the calipers. plus the 1" master cylinder.
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    lol, bangers read his post again.
    I'm positive that you don't need to change the strut, I should have my copy of the workshop manual, that 7 book one, I should have it today or tomorrow, if I find it I'll print out the pages showing the brakes on both models.
    vr statesman 5.0 + vs exec s2 auto
    Mar 2006
    central coast, nsw
    Default v8 rotors + calipers on a 6 cyl
    Dan , you have to get the caliper brackets off v8 or vl turbo, or off any commo with the 289mm diam rotors say, vn s pac,v8, vp series 2, or any vr-vs. the brackets on the smaller 270mm rotors r too small .regards Baza
    dan_man31's Avatar
    vl executive
    Feb 2005
    brisvegas
    how u mean the brackets i have the ventilated turbo calipers and the bigger rotors 290 which are supposed to fit vn spac and vl turbo/v8 everyones asked did i push the piston all the way back and i know i did cause i had the piston out to check for damage im confused lol
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I think you need to be a bit more specific. What exactly are you have trouble with? What isn't fitting?
    Visit my Facebook page
    Bax
    Nothing
    Jan 2004
    QLD
    dan_man31's Avatar
    vl executive
    Feb 2005
    brisvegas
    rotors fit car no problems
    calipers fit lines and will bolt up only if there are no pads in calipers
    as soon as you put the pads in the calipers wont slide over the rotor and will conflict with mounting bracket pads are right as well
    Dan
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    OK, make sure the slides are moving freely, make sure the piston is pushed back in all the way, it will be almost flush with the caliper. Make sure that the pads are in properly and pushed hard against the caliper and piston.
    '87 VL Calais with L67
    Aug 2007
    is there a difference in pads? there may be thinner pads with a bigger surface area, since they would wear at the same rate i think. maybe worth checking.
    This is good site to watch.I found it informative as I have been researching a lot lately on such matters such as you talk about.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    No, pads are the same.
    Mar 2006
    central coast, nsw
    Default rotors + calipers on 6 cylinder
    Dan, before u push piston into caliper remove some brake fluid from ya master cylinder so the level is just under half so ya dont force any fluid out of m/c cap. best if you use a G clamp to slowly push piston into caliper squarely so piston wont jam in bore. ya pads should be DB1085 on front wheels + same ID number pads do both 270mm + 289mm rotors,good luck.
    dan_man31's Avatar
    vl executive
    Feb 2005
    brisvegas
    using winding piston pusher am apprentice mechanic and have actually removed piston for inspection before i put them on the car gonna try puttin them on again this weekend just wondering if there was possibly a difference in strut or caliper mounting calipers were off the car when pistons were pushed back so its not gonna flood the master
    let yas know
    cheers Dan
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Sounds as though the slides aren't moving back far enough to allow the caliper to go over the rotor. Are they moving freely?
  15. #15
    dan_man31's Avatar
    vl executive
    Feb 2005
    brisvegas
    yeah slides have also been removed and regreased ill double check but i think it might be the rotor thickness have to find out
    get back to ya's
    Dan
  16. #16
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Can't be the rotor thickness if the calipers have fit them previously.
  1. PBR Brake Calipers & DBA Rotors
    By The Windsurfing VY Wagon in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-03-2008, 10:48 AM
  2. help...biggest rotors for vt\vy calipers??
    By beefcream in forum General
    Last Post: 11-01-2008, 02:40 PM
  3. Wtb: Vt Twin Piston Calipers + Rotors + Adapter Hub
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 30-12-2006, 08:54 PM
  4. painting calipers and rotors/hubs
    By VksupaNoob in forum General
    Last Post: 10-02-2006, 09:05 AM
