Hey guys trying to fit a turbo timer to my mates vl turbo and for the life of me cannot find a wire that has power with ACC on..
i got the earth and ign power sorted but cant find a acc power wire and help you guys would have as to were to look.....
back of the ign switch is the most likely place
Phillip![]()
Yeah you would think but tried that dead as no pwer at all........
just a question, his acc works doesn't it? ( as it radio etc )
We got rep back, yaaay!
For some reason the radio runs off the ign so i thinking something fishy going on with it is there suppose to be a fuse panel to the right of the steering wheel and down a bit as there are 3 plugs there but no fuse panel.....
the fuse box assy on a VL is out under the bonnet on the LHS of the car,if tgere is no acc behind the ign switch there is a problem with the switch,are you using a test light to check it ?
Phillip![]()
Test light and multimeter to test ok so there may be a fault with the ign swtich ok....
Any idea what all the plugs under the steering wheel do in the little removable panel casue this panel has a fuse diagram on the back of it...
Also another funny thing happened today with it no keys in the ign and the fan works on all 4 settings.,..![]()
they all have that diagram on there,maybe holden used up earlier panels,i cant remember what the plugs are under there been to long since i have worked on one,from memory the acc wire will be brown i think
Phillip
Just read the bit underneath about the air con workin wifout the keys in,this is normally the result of a crook ign switch or out of adjustment,or worst case scenario the barrel rack and pinion might be all worn out.
kool thanks guys, now another question:
"how to install a mini spool" into Vl turbo.
thanks guys
the problem is we hooked the turbo timer to our vs commodore ok now it all lights up like its sopose to but wen i turn the car off with the turbo timer set the car just turns off and the turbo timer too i need some real help here becouse it just dosent seem to work the way it should can someone please help me thanks.
hey there peanutz,
What sort of Turbo Timer is it. A pic would probably help....
Oh and I am sure you are aware of this but the accessories on a VL is with the key pulled backwards in the barrel not forwards (ignition).
The Brown wire on the loom is the accessory wire....
Let me know if you need anymore help
cheers
Simon
Lets work as a TEAM and do it MY WAY!!
