Results 1 to 18 of 18
Thread: My VL - Someone Wanted It More Than Me
    Apr 2008
    Default My VL - Someone Wanted It More Than Me
    Howdy All,
    Just wanted to share a little bit of sad news and vent my anger...
    This morning I walked down to my VL and noticed the front driver door not shut properly. I got into it and there was stuff everywhere (stuff I had bought to do a service on it). So I come to the conclusion someone had broken in and wanted to drive it away.
    So I went to put my key into the ignition n drive off to work, only to find a 1/2 snapped off key in the ignition......
    After a lot of stuffing around I got the 1/2 broken key out and looked at the rest of the car. They have completly ripped off the passerside front door lock (Maybe they took it with them to get a locksmith to make a keey) and come back tonight n drive it away.
    Then also mashed my driverside door lock, so I can't even lock it!
    What a bunch of tools they were. They opened up the boot, rummaged though it but took nothing. I had and still have a $300 sidchrome toolset, along with other stuff in there!
    Ok, so I now know not to leave anything on value in it, just incase next time they want my tools as well.......
    So now I have two doors without locks. I guess I'll have to go to a wrecker n get two new locks, but is it hard to put these into the doors?
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Pretty easy to put them in the doors.
    My advice is to go to Holden and get a new ignition barrel aswell, then get a locksmith to redo the door locks to match the ignition barrel key.
    That way you've got a new set and it won't match anything that they could get made up. If they do.
    From memory you just take the door trim off and it has a screw that holds it into place. I think.. It's been a while.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by VL-Cruiser View Post
    Howdy All,
    Easy to fit the locks when you have the handle out of the car. Lock is held in by just a slide type clip. May just pay to get a full lock set - doors, boot & ignision. AND a club lock too.
    and 3 Dangerous non ABS VN's
    Apr 2008
    Quote Originally Posted by 88GreenVN View Post
    Whats invovled in getting the outside handles off, is this tricky or another easy job....?
    VY SV8 HBD---mmmm LS1
    Simon Champion! On The Volley Champion! Shootin Hoops Champion! Batting Champ Champion!
    Dec 2005
    Western Suburbs
    88GreenVN's Avatar
    Jun 2006
    Cant remember at all... As Bax said ^^^ it's been a while. Just that when the door handles our out you have more room to see/move. When you take the trim off you will be able to see. I'ts not all that hard once the trim is off.
    GOTMYN's Avatar
    GOTMYN is offline Stab it and Steer...
    Whippled 5.7, VE SV6, GU Patrol 3.0DI
    Sep 2006
    Mornington, Vic
    Default lOCKS...
    Put some solex locks in it,
    Put them in my VB, and never had anyone break into it!!!!!!!!
    If I'm not pulling Toyota's out of the Bush, I'm pulling 12's in the Sig :-)
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    get an alarm to bro, once they open a door and ur interior light works, you'll know!
    if ur really worried take out an engine part.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    Mar 2008
    club lock lasts about 5 secs when they hacksaw through the steering wheel and throw it away
    want the car to remain in its location the alarm with 3 point immobiliser and a kill switch , only way it will go then is by tow truck
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    Bax
    Nothing
    Jan 2004
    QLD
    I got told ages ago that doing that was a waste of time because apparently the top bit breaks off really easily?
    I guess the only way to find out is to try it... Anyone up for a drive to the wreckers to experiment?
    dan_man31's Avatar
    dan_man31 is offline now projecting oh yeah :D
    vl executive
    Feb 2005
    brisvegas
    easy option is kill switch hooked up to your neutral switch on ur auto (if its auto )
    then it doesnt matter if they do get in they aint going anywhere
    if i have been forced to leave it anywhere like a shopping centre or car park i pull out the auto thing under my dash and put it under the seat pull the coil ht lead
    Club locks are pointless but are a general deterent when someone is looking for a quick getaway!!
    and ive heard solex locks are good in theory to stop ur mates using their own keys but are just as easy to break into using something simple as a hammer and a punch
    Its Stock And it Rocks .... ditch the bitch lets go racing
    Aug 2007
    Newcasstle
    Quote Originally Posted by dan_man31 View Post
    So when the shifter is in Neutral position the kill switch is on??? And when its in park its not on?
    vl berlina wagon 6cyl
    Jul 2005
    i had someone get in thru a door I forgot to lock and went thru everything, stealing my drivers licence
    also someone damaged the passengers door lock trying to force it but didnt get in
    in some cases the door and ignition lock wear so that any VL key will open and start almost any VL
    some sort of strongbox with lock bolted to the floor would seem needed if you need to leave anything of value in the car
  15. #15
    VT SS S2 A4
    Aug 2005
  16. #16
    Astranomical's Avatar
    Astranomical is online now Ecotec just kicked in yo
    Hammerhead Eagle i-Thrust
    Apr 2004
    Dee Why, NSW
    I once heard about someone who used seat covers on their VH, and when they would leave the car, used to put a piece of wood with a nail driven through it between the seat and the cover.
    You'd REALLY have to remember it was there though!!!!!
    Quote Originally Posted by som
    i saw a camira a while ago that wasn't blowing smoke.it was on the back of a tow truck.
  17. #17
    Vl Commodore
    Apr 2008
    Noosa
    i have a kill switch on mine but u can start it wit anything, the door also unlocks with anything aswell but then if anyone got into it i doubt they could get it in gear you pretty much have to bash it in gear and its auto
  18. #18
    xxb4xx is offline Missing my V8
    Liberty B4 TT
    May 2008
    Still no good.. a kill switch should kill all power to the ignition.. but using your setup, you can short circuit the starter motor directly from the engine bay and it will still start.
  1. Wanted : Sa :/ Wanted To Know : Vp Calais Rear Wheel
    By Ygoford in forum Swap / Wanted to Buy / Trade
    Last Post: 03-02-2007, 07:00 PM
  2. Wanted: Irs Lsd
    By 98berlina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2006, 07:43 PM
  3. help wanted !!!!
    By Spilly in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-03-2006, 07:25 AM
  4. wanted a vl
    By muffman001 in forum Swap / Wanted to Buy / Trade
    Last Post: 04-02-2006, 01:01 AM
