if its the same as a vs theres a long metal rod which goes along horizontally towards the front of the seat which is secured by two anchor points...just feel under the seat n u shud feel it and there is an anchor point on both left and right sides..just push the seat in with some force and lift the metal rod closer to the anchor point at the same time...
hope this made some sense
if theres headrest they pull rite out, then twist the four plastic clips 90degress and then wiggle them out
then at the bottom of the top part of the seat there is 2 clips (one each side) that need to be bent up just get a screw driver in there and bend them up
seat sould just pull forward now move seat belts out of the way and pull seat out
hope it helps
