Results 1 to 22 of 22
Thread: vt commodore windscreen seal on vl?????
    starfire vc's Avatar
    starfire vc is offline now on 10 pound
    VL turbo, RB30ET VH wagon, 64 EH in the build.
    May 2007
    Brisbane,North
    Default vt commodore windscreen seal on vl?????
    Hey all. was goin to mention this in my other thread but i deciced to start up a newie. had a look for info on jc regarding the use of diffrent windscreen seals on the vl but couldnt find anything.Ive heard of people using vt seals ,that they fit straight in. is it definatley the vt seal thats used?
    When the cars goes off to the panel beaters iam allso goin to get them to take the widscreen out and treat the bit of rust thats just starting to come thru in a few small places and yer hopefully reinstalled using the vt seal.any info appreciated.
    the germans designed it, the aussies built it, the japs got it moving and the wogs got it dosing...
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    never heard of it, and honestly dont see how it would fit, and if you made it fit id imagine it would look like ****. Anything VB -VL should fit but VN onwards is a completly different seal. Im all ears though, and if you do it post some pics.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    May 2007
    Brisbane,North
    yep thats the one . thanks for that picy vl 5speed..
    i rekon they just look a alot cleaner than the factory vl item. and will be definatley getting a vt seal put in when the front screen comes out.
    VT SS S2 A4
    Aug 2005
    It is a universal seal, any windscreen place will be able to do it and it should be cheaper than using a VL seal.
    You will need to fill in the holes where the original moulds were fitted.
    My VL looks Grandpa spec..lol
    executive vt 5.0lt
    Feb 2005
    west suburbs
    bax has some pics of his car and he used a universal seal i think ??was it vt ??
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    The picture has definitly changed my whole view on this. WORKGUIDE, i wanna do it to the VK, anyone know if it helps with stopping rust under the seal?
    May 2007
    Brisbane,North
    Quote Originally Posted by Tom_1569 View Post
    yer looks a heap better hey... not sure bout preventing rusting? time will tell i spose
    VT SS S2 A4
    Aug 2005
    Aug 2007
    Newcasstle
    Yep Im going to be doing this. For some reason when it rains heavy my car starts leaking water from the top middle of the windscreen... THERES NO ****ING RUST!!!!!!!!!
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by VL_5SPEED View Post
    No rust because the waters leaking right through and not causing any moisture
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Mine leaks on the passenger floor. Lucky the ECU is wrapped in plasic lol. Might put some of that toyota windscreen black tar muck that I have into the rust holes.
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by Wavez View Post
    May not be rust holes (at a guess oviously you have seen your car) but if where your air/con intake thing is can get blocked up with leaves on the water drain so the water leaks through the heater and down to the passenger footwell before anywhere else for some reason. Hmmm thats really hard to explain.
    Chirpstr's Avatar
    Sep 2007
    Yeah nar I wish haha. It's rust at the bottom of the windscreen and it runs down to the floor of the passenger side. This is the only bad thing about my VL at this stage. Any suggestions on a temp fix? Putty or something?
  15. #15
    Aug 2007
    Newcasstle
  16. #16
    Chirpstr's Avatar
    Sep 2007
    well good enough to bog I would say, but maybe i'll need to rust convert it then sand it out, then fill...
  17. #17
    May 2007
    Brisbane,North
    iam looking at bout 700$ to get the rust around my front screen repaired. this includes a new windscreen reinstalled using a vt seal and having the two holes that the standard windscreen mould use filled and repainted. i rekon thats preety good.....
  18. #18
    VS daily // V8 Hilux // Merc 190E
    Feb 2007
    WA Perth, Joondalup
    How much do you reckon a place would charge to just do new windscreen with universal seal??? (i can remove my windscreen and fill the wholes myself)
  19. #19
    VL Turbo Wagon
    May 2008
    Nooow Zeelind
    May 2007
    Brisbane,North
    hey mate that looks good.
    do you know if you had to take out the head linning to weld up the two holes used to clip the mould into? the panel beater wants to take mine out cause he thinks it mite set the linning allight wen he welds the holes up
  21. #21
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    What are the holes, i havent pulled my seal out so i dont know what it looks like, im actually dreading taking the seal out caus i dont want to know how bad the rust is.
    Also would it be worth me pulling out the seal to check the rust and then put it back in, is it much work to get back in?
  22. #22
    VL Turbo Wagon
    May 2008
    Nooow Zeelind
    The hole's are pretty small I just gave it a quick zap with the mig with some cardboard slipped in between the roof liner and the roof no need to pull the whole roof liner off although I will be doing that when I mig the holes on the roof from the roofracks and the chrome strips.
    The factory seal is not much it's 2 strips of seal top and bottom with your plastic covers left and right then when thats all off you will be left with alot of black silocone around your screen piano wire is the way to go you need a freind for this, one on either side of the screen work the wire back and forth all the way round the screen
LinkBacks (?)
  1. vr commodore windscreen wiper problem
    By craig_maxfield in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2008, 08:33 PM
  2. Windscreen Rubber Seal Reseat
    By Sam_100 in forum General
    Last Post: 06-11-2006, 06:51 PM
  3. holden/commodore windscreen logos
    By EGG in forum General
    Last Post: 02-06-2006, 05:28 PM
  4. Front windscreen leaks water at the top seal
    By frustrated in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-03-2006, 08:21 PM
  5. Windscreen Seal... And Other Stuff...
    By loweredvsute in forum General
    Last Post: 15-03-2004, 11:56 PM
