Do I need a new Ignition Barrel?
I'm up for registration and they won't pass the car because the ignition key will come out of the ignition barrel when the car is moving.
I tried my spare key (newish / hardly worn) but that too comes out of the ignition barell when I'm driving.
Any ideas how I can fix this problem without great expense?![]()
Maybe this is only for NSW Registration requirements?
Mine does that also. And the horn doesn't work, and it has chopped springs. And they still pass it.... Just take it to someone dodgey who will pass it.
1988 VL Berlina turbo 5 speed
http://forums.justcommodores.com.au/...ml#post1446411
1987 VL SL turbo 5 speed ~STOLEN~
http://forums.justcommodores.com.au/...ed-manual.html
haha,
I need a working horn![]()
Mmm, now who could I find
Ahh, don't think I'd have much luck in Sydney as all the rego inspectors are top blokesCough
I'm just wondering if ya took the key out whilst driving would the steering lock come on? Don't try it though
I think the steering lock only engages when the barrel is in the start position
Saw some new ignition barells & keys for about 40 bucks so I might just buy one as I'd hate something to go wrong.![]()
Nope the steering lock doesnt come on... I sometimes take the key out while driving. My mates are like wtfffffffff whys the car still going.
Where abouts in sydney are ya from? suburb wise.
My old VL did the same thing. It was great when getting home and was able remove the keys to unlock the shed with the car still running![]()
lol u must go to a really picky basted to nab u on an ignition barrell .. lol every pre vn commodore ive owned has done that lol
wrecking VL COMMODORE 5 speed
FOR SALE : supra 5 speed box suite holden v8 $800
...or you could just simply attach a quick-realease clip to your key-chain and clip your car keys to that, then when you pull up to your drive way simply unclip the key chain from the car keys and unlock your car hole
and save you the trouble of putting back the old busted ignition barrel.
Well, no problems installing the new ignition barrel but when I re-connected the negative earth to the battery the horn just won't stopShe just keeps on and on until I dis-connect from the negative battery terminal.
I thought may be I'd buggered up something underneath the pad (the thing ya push that normally does all the tootin; but even with the pad disconnected from the electrical wiring connector the horn still bellows as soon as I reconnect the negative battery lead to the neg terminal.
So now I'm wondering what I've done wrong?
There's power continuously going to the horn.
I'm sure the new ignition barrel was installed ok but I'm F---ed if I know what's gone wrong.
As a temporary measure I got underneath the car and disconnected one of the electrical connectors to make the horn un-operational.
The car starts up no worries, the accessories work ok and the steering lock works ok
Any Ideas from you guys would be great![]()
Everythings ok now with the ignition etc but a warning to others if you replace the ignition barrel.
This is probably well know by mostbut the new ignition barrel I installed of course comes with a new key. The old key from the old barrel obviously opens the door locks and boot
but guesss what
the new key will also open the door lock and boot.
Now I always use my "Aunger" steering lock; I've also got a set of new door locks that I'll be fitting soon.
Hope this info helps from stopping someone stealing your VL.I hate car thieves especially the Pr---- who stole my VN
Ahh yes, the old VL key thing. If there was one feature I wish my VN had, its that one. I used to park the car, leave it running and lock it while I went into the dairy or whatever. Makes people think it's a VLT with a turbo timer![]()
JetSpin Racing Team Mantre:
"F**k safety, I'm in a hurry"
bUST THE gear lock..hotwire the thing and away ya go...or better still bung in some WD40 and work the key in/out for a while and see if the tumblers inside loosen up..worked for a mate in his old veedub. Otherwise get a new barrell... good luck.
Beg to differ... never use oils of any kind on locks. WD40 you might get away with, but for the most part they will gum up the lock after a period of time and you'll be worse than when you started. Keys and barrels should only ever be lubricated with graphite powder.
