Results 1 to 15 of 15
Thread: Help! VL Bonnet Cable Snaped!
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Default Help! VL Bonnet Cable Snaped!
    The VL bonnet cable snapped just then. Before I would pull the lever and giver the corner a couple of light hits and she will pop up and was happy to live with that now I just did the same thing and I heard it snap.
    Check at the lever and can pull the cable so it snapped for sure.
    Anyone got any suggestions? I put a crowbar in the center but I dont really want to give it too much more because I think I'll break the plastic nose panel...
    jetspin_vn's Avatar
    jetspin_vn is offline JetSpin Racing Team
    VN GTS
    Nov 2003
    Mission Bay, Auckland, New Zealand
    The best way to get in is from under the front, prise the springloaded twang back with a screwdriver. Holden still sell the cable new, comes with a new lever and will set you back about $40 and 45 mins to install.
    Might do a how-to on this tomorrow, im sure it's happened to a few people now me included on both my VL and VN.
    JetSpin Racing Team Mantre:
    "F**k safety, I'm in a hurry"
    Chirpstr's Avatar
    Sep 2007
    Quote Originally Posted by jetspin_vn View Post
    Ok Cheers mate! I'll give it a crack tomorrow. I had a quick look under there through the little metal squares not much room to play with but I'll give it a shot, hopefully I wont have to take the front bumper off, Just put it back on lol.
    86 VLCT/ 03 II VY SS Ute
    Aug 2007
    I just got one from the u pull it cost me $9 and it shows you how to get the old one out before you try on your car and break anything. I would be suprised if it takes you 45 mins, it seriously took me about 15
    Chirpstr's Avatar
    Sep 2007
    ok cheers mate yeah I'm thinking about getting one from the wreckers. I can get any commodore bonnet cable right? VB-VS? maybe onwards....
    Aug 2007
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Yeah another vl would be best ideally, I wouldn't get a second hand one it'd be just as much trouble.
    I'm going to drop my car off to the mechanics tomorrow and get him to chuck a new one in while he has it.
    Pretty easy job to get them out though, even easier considering it's snapped. Unhook it from the spring at the front and pull it through the firewall. The lever bit slides off easy.
    As jetspin has said thats the way to do it, I got mine the other day by going through the grill with a screwdriver, wedged it in there and it popped.
    Chirpstr's Avatar
    Sep 2007
    I would like to say I got it, but it wasn't overly easy. I had to take out the letter box grill so it would make things a little bit easier. ****ing around for an hour trying to get the little latch, bloody fan was in the way. Cut myself and kept going and finally got it.
    YAY
    No need to buy a new cable. I just used a little metal clip that I found then used some accelerator wire that I had. I rejoined it to the broken part then wrapped the end around the latch. It Actually works better than ever!
    vl berlina wagon 6cyl
    Jul 2005
    Bax
    Nothing
    Jan 2004
    QLD
    Just spray some wd40 or something up the end of the cable, that's about as much as you can do I guess.
    Jezza's Avatar
    Jezza is offline Ecotec Just Kicked In!
    VYII Acclaim
    Apr 2009
    South Australia
    sorry to bump a old topic (better than creating a new one) but mine has broken recently and do holden still sell new bonnet cables with the lever? and what do i do to install it
    Bax
    Nothing
    Jan 2004
    QLD
    Best bet would be to call Holden and ask them But I'm fairly sure they do still sell them.
    Installation is the opposite of removal, tie the bonnet end of the cable to the lever end of the old one, pull the old one through the firewall, follow the same route as the old with the new one, reconnect the latch, make sure the screw is holding the cover. You may need to provide some more slack/tension by moving it along.
    And hey presto you have a new cable.
    Jezza's Avatar
    VYII Acclaim
    Apr 2009
    South Australia
    um i dont know how to remove it because when it snapped i tryed opening the bonnet by pulling the cable and it came all the way out and we had to cut it :S
    VL RB30E
    Aug 2009
    i bought on from holden late last year for $49 but i forgotten how to change it over
  15. #15
    Bax
    Nothing
    Jan 2004
    QLD
    Quote Originally Posted by VL3.0L View Post
    So you can't open the bonnet at all? You can either find out where the cable snapped and give it a pull, or you can take the grille out and go nuts with a flat headed screwdriver. If you take the grill off you can see how it works and you just have to push it from there.
LinkBacks (?)
  1. 21-11-2011, 09:19 AM
  1. Bonnet release cable snapped how do i open the bonnet
    By S-Pac_Sam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2010, 09:07 PM
  2. bonnet cable issue
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-09-2007, 10:31 AM
  3. bonnet cable
    By zohpm in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-04-2007, 04:12 PM
  4. bonnet cable broken please help
    By jolea682 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-01-2007, 05:16 PM
  5. VN Bonnet Cable Snaped
    By VN-SV-89-LE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-09-2006, 09:49 PM
